Home > Maintenance & Modifications > MY 2013 RRS Heated Steering Wheel Upgrade
Page 3 of 4 <1234>
Lonescout
2006 Range Rover Sport TDV6 HSE Cairns Blue
This is my wheel from a D4. The received wisdom is to get one without the white horn symbols on the switch packs, for earlier models, so that the control module for the heating element is compatible. As you can see mine has the white horn symbol yet has the earlier type module. I contacted the seller who was quite happy to take the wheel back if it didn't work. The image he'd used on the listing was one of his stock images and not the actual item!
On this page is an image of the two modules along with one information so you may identify the right wheel for your application.
http://www.disco3.co.uk/forum/topic44385.h...;start=585
As I've said, there is a whole host of info on this topic (and other stuff relevant to the RRS) on the Disco3.co.uk forum. Especially if you want to mod your vehicle. They seem to be more given to modding over there Cool
Post #528687 Wed Jun 21 2017 4:05pm
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi Lonescout,
Thank you very much for all the info, it has helped me a lot to figure out just what is and what is not compatible with my car. The link and tip regarding the Disco3 Forum has also been very useful, I will have a good dig around on there tonight.
Cheers Thumbs Up
Steve
Post #528694 Wed Jun 21 2017 4:59pm
Steve,
Another issue I see with using a complete D4 wheel is also finding one with the correct switch packs, as you car is a MY13 I would imagine it has the noble trim on the c/control, phone buttons etc. also the horn push buttons as well. Not all discos had them if any but sure someone else can answer that. In addition if you have ACC you would need a wheel with that pack as well. You could use your original switch pack for that but unless the Disco wheel had the noble they would not match cosmetically and that would annoy the hell out of me personally.
I'm certainly not trying to tell you what to do, but from a personal perspective I would buy new as all you need is bare wheel which comes with heating ecu. and a r/h switch pack plus possibly a clockspring which you may have to buy whether you use a disco or sport wheel. L/R parts list says after a specific vin no. they all had the heated clockspring fitted but that is not the case so just pot luck if it is or not. The other option is keep looking for a complete wheel from MY12/MY13 Autobiography as I think all A/Bs had heated wheels as standard and should be a straight swap.
Apologies for waffling on.
Post #528720 Wed Jun 21 2017 11:07pm
Evo5man
Thanks Col,
I am quickly learning that you are both a fountain of knowledge and provide very sound advice with a similar outlook to me Bow down
If the finish did not match it would annoy the hell out of me too!
I think that my plan will be to look for a MY12/13 RRS L320 Autobiography Wheel as you suggested to ensure compatibility and if one does not turn up by the UK Autumn, I will bite the bullet and order a new wheel and switch pack.
Steve
Post #528723 Wed Jun 21 2017 11:20pm
Thanks for those words Steve, but I think the problem is I have to much time on my hands these days and can play about with things and delve into bits and pieces. Laughing
Gerd1986 wrote:
@col - Does the piano black part of that steering wheel heat up also or is it just the leather part?
Yes it does but it is negligible, but saying that even the leather part only gets warm not what could be described as hot might be because the wheel is quite chunky or slightly faulty not sure, can't even remember how hot original wheel got. Don't really need it down here middle of winter and has been 18 degrees last couple of days. Cool
Post #528726 Thu Jun 22 2017 4:16am
Buckster
Now you can see why i went for everything new. After the 2014 Disco 4 episode i was done with the headache of trying to sort out the different combinations and multiple switch packs!! Big Cry 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #528729 Thu Jun 22 2017 7:23am
Evo5man
Hi Buckster,
I agree, the forum has saved me a lot of heartache trying all the combinations of wheels, switch packs and Clockrings Thumbs Up
Forums are great for this sort of thing. There is normally someone out there who has done what you are trying to do.
I owned a Mercedes and 2 main dealers said that modifying the Fibre Optic Ring could not be done, one post on the Mercedes Owner's Forum and I had it sorted with full instructions and photos Thumbs Up
Steve
Post #528734 Thu Jun 22 2017 10:19am
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
The IIDtool *should* enable the heated steering wheel as I have seen the option while perusing the app. As for the airbag, I would guess that simply connecting it back up will enable it after a hard reset.
Post #528941 Sat Jun 24 2017 7:41pm
Evo5man
Thanks CANROVER for your input Thumbs Up . I plan to fit the wheel and new clock ring and do a hard reset. If the new heated steering wheel is not recognised, I will seek an independent specialist to enable the heated steering wheel option.
Cheers Thumbs Up
Steve
Post #528945 Sat Jun 24 2017 8:36pm
Cymru001
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Hi all,
I know I'm looking at an older thread and am hoping the original posters are still about or maybe someone else can help?
I am wondering what iiD tool people are using to activate (if required) the heated steering wheel? I am looking to get this upgrade on my 2012 RRS. I have pored over this thread and think I have all I need (I've even bought a new clockspring before checking if mine has the extra terminal required!!).
I also going to get remote heating added, (parts and fitting instructions also found here so thanks for that), so would like to know if I can activate remote and timed heating with the same iiD tool?
I know the iiD tools are expensive to buy but I think I can save money in the long term by being able to a) activate features myself - local indy wants £50 per feature, and b) being able to diagnose faults which I can then repair, if not too difficult, and clear myself.
Thanks in advance for any help.
Post #586357 Wed Sep 04 2019 8:23pm
Lonescout
Hi, I didn't need an IID tool for mine. Just plug and play.
Post #586366 Wed Sep 04 2019 8:48pm
Evo5man
Hi Cymru001,
When I retro fitted my heated steering wheel and reconnected the battery it was instantly recognised with no need to change any configuration files using a IID tool.
I also retro fitted the remote heater system and this did need to be initialised using a GAP IID Bluetooth tool. A great piece of kit but not cheap. If you are planning to keep your RRS for a long time, the GAP IID tool is a great investment and I would highly recommend it.
Post #586367 Wed Sep 04 2019 8:50pm
Cymru001
Hi Evo5man,
Thanks for the quick reply. Did you have the correct clockspring or did you have to swap it out? I'm wondering if the car has the correct clockspring then all is good or an initialisation is required if the spring is changed?
Post #586369 Wed Sep 04 2019 8:55pm
Evo5man
No, I had to change the clock-spring, you will be very lucky if you already have the heated steering wheel clock-spring fitted. But even with changing the clock-spring, I still did not need a IID tool. Just plug n play for me Thumbs Up
Post #586370 Wed Sep 04 2019 9:08pm
Cymru001
Great news. Thanks for letting me know.
Post #586379 Wed Sep 04 2019 10:46pm
Page 3 of 4 <1234>
