![]() | Home > General > Park brake cables |
Didn't think you could get the cables separately, thought they came complete with the actuator.. 2008 G4 RRSport TDV8 current
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
About 90£ each but there on eBay 61 AB 5.0 supercharged rocket
You need to open up the actuator module which is underneath, just in front of the spare wheel.
Looks like a bit of a mission but in case it helps here's a link to the workshop manual instructions:
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4508 ![]() ![]() ![]() |
Os cable is fiddly, but easy enough.
Thanks that's my next challenge 😔😔😔 61 AB 5.0 supercharged rocket
SteveNorman Member Since: 18 Sep 2008 Location: somerset Posts: 7 ![]() ![]() |
Both cables can be renewed. O/s is clipped into the actuator, the N/S is screwed in. You don't need to remove actuator or open it up to fit, just unscrew the large plastic nuts, then unclip O/S, or unscrew nearside.
