Home > Technical > Tdv6 water temp sensor
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Where is the temp sensor that works the gauge on the dash, mine keeps intermittently not working ?
Post #528374 Sat Jun 17 2017 4:36pm
same as the engine ecu one, at the front of the engine.
Post #528376 Sat Jun 17 2017 5:00pm
m3nutter
Thanks Andy
Post #528378 Sat Jun 17 2017 5:32pm
m3nutter
Is the gauge oil temp or water ?
Post #528379 Sat Jun 17 2017 5:47pm
Water I think
Post #528382 Sat Jun 17 2017 6:02pm
m3nutter
Yeah makes sense mate
Post #528387 Sat Jun 17 2017 8:31pm
m3nutter
Symptoms
Gauge doesn't register seemingly until thermostat opens ? Where's the sensor ?
Post #528495 Mon Jun 19 2017 6:24pm
Bodsy
Site Sponsor
I'd be looking at the oil temp sensor first. When it fails (and the oil sensor fails more than the water sensor)
Then it also has a knock effect of showing false or no readings on the water temp.
Are you able to look at live values? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #528513 Tue Jun 20 2017 1:25am
m3nutter
No mate I don't think I can , are you saying even though the gauge is saying it's ok at half way up , when it's working , it may not be ?
My only peace of mind is the fan seems to operate ok
Where is the oil sensor ? In the sump ?
Post #528518 Tue Jun 20 2017 5:28am
m3nutter
How do I measure live values Ian ?
Post #528519 Tue Jun 20 2017 5:32am
you need an IID or diagnostic machine to see live values.
yeap, oil sensor is side of the sump.
Maybe worth disconnecting it ? and seeing if water gauge is better.
Best to look at live values first, if you can
Post #528534 Tue Jun 20 2017 9:24am
m3nutter
just thought id post back to answer the findings.
changed the oil temp sensor in the sump £35, and all good. temp gauge works fine and truck runs better Thumbs Up
Post #530538 Mon Jul 17 2017 11:55am
AndyCHO
Australia 2010 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
After doing around 1500km on the weekend in the RRS in a quick trip to Sydney and back I noticed that the Temp gauge stays on the low position regardless of the temp.
Reading back through here it appears it could be either the Water Temp sensor of the Oil Temp sensor.
How do I check which one it might be using Live Values from the GAP IDII tool?
Post #623544 Tue Apr 12 2022 11:25am
Well live values, then engine paremeters .
However if the oil sensor is short circuit, it still won't give you a 100% answer.
If you were to disconnect the oil sensor, then read water temp or look at gauge that may tell you
Post #623546 Tue Apr 12 2022 12:42pm
