| RRSPORT.CO.UK | ||
|  | Home > Technical > Sudden Battery Discharge |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025    | I'm no auto electrician but suggest checking alternator is working ok. They usually take out the battery when they go so best replace both if it turns out to be the alternator.
|  Sun May 14 2017 12:50pm |
| Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254      | Probaly sort cut within the battery. (plates made contact). happens sometimes, particularly in hot conditions.
|  Sun May 14 2017 4:02pm |
| donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772    | I agree wth Hog, it sounds like your battery has gone kaput with buckled plates and needs replacement. | ||
|  Sun May 14 2017 4:22pm |
| warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234      | How old us the battery? Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 | ||
|  Sun May 14 2017 7:34pm |
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145      |
 I'd say DrRob,s suggestion is likely, mine is tdv6 but did exactly same on my wife one night, had to get relayed home, had zero volts in no time at all. Off loaded at home by fitting a spare battery I had but with it ticking over and a meter on you could see volts going down rapidly . Not certain but likely mate | ||
|  Sun May 14 2017 8:49pm |
| squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193      | I would 2nd Dr Rob. We had it, the car was driving perfect then all of a sudden the dash lit up like a Christmas tree and the car cut out. brand new battery was dead flat, recovery came and used a power pack to start it and get it on the back of the truck, but it drained this in a matter of seconds. Alternator had gone and wrecked the battery, battery was replaced under warranty as it was 1 month old, and would no longer accept a charge, fitted a new alternator, cleared loads of fault codes it caused and its been perfect since. | ||
|  Mon May 15 2017 5:06am |
| Staftly Member Since: 25 Mar 2013 Location: Lancashire Posts: 5  | Hi all,
|  Mon May 15 2017 8:42am |
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145      | I kidded my iffy battery which was dead flat by charging it through another good battery and the volts did gradually come up | ||
|  Mon May 15 2017 7:56pm |
| donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772    | A lead-acid battery that has become totally discharged will never be quite the same again. | ||
|  Mon May 15 2017 8:20pm |
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145      | Quite agree mate, but never say never | ||
|  Mon May 15 2017 8:23pm |
| Posting Rules
 Have since attached a multimeter and tested for continuity whilst pulling all relays & fuses in the engine compartment bay. I am seeing that I have an "open circuit" regardless of what real/fuse is pulled. I haven't yet continued this test with the fuses located under the passenger footwell, but I'm guessing these are likely to be lesser rated and should have "popped" given the rate of discharge.
