![]() | Home > Technical > Sudden Battery Discharge |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2026
I'm no auto electrician but suggest checking alternator is working ok. They usually take out the battery when they go so best replace both if it turns out to be the alternator.
| Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254
Probaly sort cut within the battery. (plates made contact). happens sometimes, particularly in hot conditions.
| donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772
I agree wth Hog, it sounds like your battery has gone kaput with buckled plates and needs replacement. |
| warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234
How old us the battery? Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145
I'd say DrRob,s suggestion is likely, mine is tdv6 but did exactly same on my wife one night, had to get relayed home, had zero volts in no time at all. Off loaded at home by fitting a spare battery I had but with it ticking over and a meter on you could see volts going down rapidly . Not certain but likely mate |
| squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193
I would 2nd Dr Rob. We had it, the car was driving perfect then all of a sudden the dash lit up like a Christmas tree and the car cut out. brand new battery was dead flat, recovery came and used a power pack to start it and get it on the back of the truck, but it drained this in a matter of seconds. Alternator had gone and wrecked the battery, battery was replaced under warranty as it was 1 month old, and would no longer accept a charge, fitted a new alternator, cleared loads of fault codes it caused and its been perfect since. |
| Staftly Member Since: 25 Mar 2013 Location: Lancashire Posts: 5 |
Hi all,
I kidded my iffy battery which was dead flat by charging it through another good battery and the volts did gradually come up |
A lead-acid battery that has become totally discharged will never be quite the same again. |
Quite agree mate, but never say never |
| All times are GMT |
