Home > Technical > Detachable towbar query
Stevieg330
Hi everyone,
My first post as we picked up our new to us RRS last Saturday. What a car, so comfortable and it's lovely to drive. We have bought it to replace our BMW 525d touring and will use it for towing our caravan.
The car has never towed as far as I can tell but the previous owner didn't have the bung in the receiver so there is some corrosion but I think I've dealt with that.
I have bought a Land Rover towing neck for it which came today and this is what my question concerns. In the instructions it says that when you lock the neck in place the red ring must be completely covered by the green handle. On mine it appears to lock in place, there is no movement and I can take out the key. However there is around 1mm of the red ring showing. Is this right or should it really be completely covered?
Perhaps someone who uses the detachable one could kindly let me know. I have to be sure all is ok before I put the caravan on it.
Many thanks and regards
Steve
Post #525166 Wed May 03 2017 2:46pm
Where did you purchase the towbar from?
There was a recall on them and LandRover converted the factory ones to a fixed towbar which is what you want with a caravan
Post #525183 Wed May 03 2017 6:43pm
geoffsnook
They will only change them if the play is above a certain amount which is quite a lot if you cant move the tow bar in the socket it should be locked in if you can stand on it and try and push down on it hard and it does not move it should be fine Thumbs Up
Post #525194 Wed May 03 2017 8:50pm
GodivaNige
If you can remove the key then I am fairly sure the towbar is safely locked.
I towed our caravan twice with the detachable towbar before deciding a fixed bar was the safer option. With the detachable in place it felt very solid, in my mind nothing would shift it, however after towing the van (a 1900kg twin axle) when it came to unhitching the towbar was found to be lose in the socket, only around 5mm of play but enough to be a worry.
Remove and refit the item and it was solid in the socket again, until the next time the van was unhitched...
After reading a few of the stories on the internet about detachable bars wearing the socket away with prolonged use and seeing a few you tube videos of some very loose bars, I opted for safety and had a fixed bar fitted. Yes it's ugly, but the van isn't going to end up causing a very big messy accident on a motorway.
I had the detachable bar checked at a dealer and there wasn't enough play in it to warrant a Land Rover freebie, so I ended up paying for it myself for peace of mind.
Post #525198 Wed May 03 2017 9:08pm
stagfinder
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
recall
I think the recall was q393 for the towbar
Post #525212 Wed May 03 2017 11:58pm
stagfinder
recall
Hi had mine checked at dealers told it was OK told them not happy and would email jlr at coventry and got a reply from them to book in back in with dealer to arrange for a new bar to be fitted but told them still not happy and wanted a heavy duty muti hight fixed and they just gave in and said OK if thats what you want we will fit it for you FOC so now still have the 250kg max nose weight if required as the detachable has been down graded to 150kg
Post #525213 Thu May 04 2017 12:09am
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I'll need to check my detachable hitch too then, I wasn't aware of it. I think I'd rather just tow with my other LR's rather than fit that unsightly contraption to the RRS.
stagfinder, If you don't mind me asking, what kind of trailer do you have that has a 250kg noseweight (or above 150kg) rating, as my local aggregate yard often loads my trailer to be vastly nose heavy so a heavier limit could be handy, although not ideal to drive this way?
You may well know this but incase you don't then if it's an Ifor Williams then although they may have 150kg/350kg stamped on their heavier trailers, All IFW trailers are restricted to the 150kg noseweight rating (I mention this being that IFW seem to be the most popular trailer manufacturer). I emailed IFW asking why the 150kg/350kg on the hitch plate and below is the reply. I also asked about their website FAQ saying for in my example a 1.5t rated vehicle can legally tow a 2.5t gross trailer providing the laden trailer gross was not above 1.5t, so I've included this part of the answer as this seems to be opposite to the vast majority of information/rumours out there.
Apologies for the delay in getting back to you with your query.
· Both values on the coupling plate are a maximum.
· The Knott over-run couplings (and also the Knott heads/eyes) were historically approved to EC regulations – e1, in this case: S-value – 150kg.
· They were recently re-approved to UN-ECE regulations –E1, in this case: S-value – 350kg.
· They now have dual-approval to both sets of regulations, hence the two figures stated.
Ifor Williams Trailers are EC Whole Vehicle Type Approved, which references the relevant EC over-run coupling approval. Therefore the figure from the EC approval is the one to use. This figure also appears in the trailer Certificate of Conformity – Item 19.
So in effect, though the coupling is approved to a higher level, the trailer is approved to a maximum nose weight of 150kg.
Note, the nose weight of the unladen LM126 is about 91kg, and when it’s fully laden (evenly distributed) it’s not going to differ much from that at all.
With regards to licences, the website is correct. If you passed your test prior to 1997 (or have done your trailer test) you are okay to tow a trailer with a maximum gross weight of 2.5t with a vehicle that has a towing capacity, as long as the true weight of the trailer (including load) is less than 1.5t.
However, if you passed your driving test after 1997 and do not possess the B+E section of your licence, the above is illegal. If this was the case, the trailers maximum gross weight would need to be down plated to 1.5t (Using your example weights) – Ifor Williams offer down plating as a service. If needed, a down plated plate can be purchased through our Spares Department for £40 + VAT.
In summary:
Licence obtained prior to Jan 1997 (or B+E) – Towing limits go on actual, true weights.
Licence obtained post Jan 1997 – Plated weights come into effect. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #525214 Thu May 04 2017 1:14am
Stevieg330
Detachable towbar
Many thanks for the replies. I had read up on q393 and as I understand it Land Rover are saying that the main reason for the problem is that the towballs were being left in the receiver more or less permanently and this lead to premature wear and consequently the movement of the towballs in the receiver. I've always used detachable bars and never had an issue. It was a Westfalia removable bar on the beemer we just chopped in and that was still solid after 7 years of towing.
Mine is certainly solid at the moment and I'll be towing the caravan to the dealers in a couple of weeks so I'll see if any play develops. I would still like to know if seeing 1mm of the red collar is normal if anyone uses the detachable version.
Steve
Post #525235 Thu May 04 2017 9:48am
GodivaNige
The Westfalia detachable towbar on my previously owned Toaureg was faultless, always solid. The LR towbar I had the issues with was not in the same league. It was new, never used and my car was never used for towing prior to me owning it as far as i'm aware as it didn't have electrics fitted and no evidence that electrics had previously been fitted and then removed.
Steve, only you can judge the suitability of the LR detachable in comparison to the Westfalia. After you have towed your caravan with it, when you come to unhitch check it is still as tight in the socket as it was when you started your journey. As recommended, I applied a liberal dose of grease to the blade and the locking pin prior to installing into the socket, to try and prevent too much wear happening but I still couldn't bring myself to trust it.
In answer to your question about the visible red ring, sorry can't help by doing a comparison as I sold the item, hopefully someone else can confirm this for you.
Post #525237 Thu May 04 2017 10:01am
samd
Re: Detachable towbar
Stevieg330 wrote:
Steve
Mine certainly has a small band of red showing and works fine. 1mm sounds about right. Not near mine at the moment but I suppose a good test would be to take it out of the socket but make sure that you have not fully unlocked it so that, on removal, it's in the locked position.
Post #525240 Thu May 04 2017 10:14am
Stevieg330
Detachable towbar
Hi all,
Thanks GodivaNige and Samd. Yeah I'll be checking it as soon as I detach the caravan although this will only be a 30 odd mile trip to drop it off at the dealers. If I do get play in it then I will definitely have to have a rethink. I don't want a fixed towball if I can avoid it but safety has to be paramount.
Thanks again
Steve
Post #525241 Thu May 04 2017 10:38am
riverblanche
Hi Steve,
at the end of the day only you can decide which tow bar you are happy with Question
Did you buy a new or second hand towbar?
book into a L/R dealer and get it checked (they also check how far the lock rotates when fitted) would they sign it off as OK and give you a yellow label with instructions on if there was a chance of failure (potential claim)
L/R just like most other companies provide a Detachable towbar for "Occasional use" a caravan maybe !
if you tow a trailer everyday then may be that is not "occasional" and a fixed towbar is more appropriate
I don't think L/R make towbars themselves but buy them in, have a look at Thule bars
My removable bar is fitted 1/2 hour before connecting the caravan and removed when we get to site and the red plug put back in, more to stop it being nicked than anything else Rolling Eyes it is kept clean with the taper dry and the pin lubed I also push the little pin when removed so I can lock and take the key out before putting back in the boot
from memory you can still see a smidge of red
everyone has their own thoughts just Don't leave it in all the time
Post #525413 Fri May 05 2017 7:32pm
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Thule in Nuneaton produce the LR tow bars Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #525418 Fri May 05 2017 7:53pm
Buckster
Can always use one of these for extra piece of mind Thumbs Up
https://www.ebay.co.uk/itm/152509328385 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #525439 Fri May 05 2017 10:38pm
M3DPO
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Re: Detachable towbar query
Stevieg330 wrote:
Hi everyone,
on it.
Steve
Give the tow bar a good whack with a rubber hammer or stout piece of wood to make sure it has fully seated, I used to do this every time I fitted the towbar, check the bar for movement after 2/3 miles.
Book it in at any LR main agent for a free check, if there is any wear they will replace the towbar and/or the rear crossmember without charge particularly if you tell them you use it for towing a twin axle trailer, the removable towbar has been downgraded to occasional light towing only.
I have towed a twin axle 000's of miles with a detachable bar on a D3 until it started to rattle loose, LR sorted it free of charge. Thumbs Up
Post #525447 Sat May 06 2017 8:23am
