![]() | Home > Technical > Webasto Software |
| RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280
That shows laptop is connected to FBH with no faults logged
| Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394
Thanks for the reply Rob, maybe a stupid question but does the engine need to be running or can the FBH be triggered without and just by the laptop |
Not a stupid question at all.
Brilliant cheers for the information Rob I will give it another go |
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134
Brilliant thanks for the information will let you know how it goes. |
hi, sorry I never replied before I'm just looking back at my post as I'm going to give the software another try soon , as the cold weather is slowly creeping up. The problem I have is the fbh works for a while then just stops for no reason ? Last time I couldn't run the fbh wasn't sure if the ignition needed to be on |
Usually it's because there's not enough airflow, so starts to fire up, then goes into cooldown mode. I've taken quite a few of these apart for that issue and it's just a case of cleaning out the burn chamber. Bodsys Brake Bible
