Home > General > Bit of technical help needed...new owner . |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
The drivers heated seat is likely to be the element in the heating pad, there are 2 one in the base and one in the backrest, I took a chance and ordered the seat base one and replaced it, all good now. I replaced the foam base at the same time as the foam bolster was sagging. About £100 for the pair and an hours work . Nanocom Evo |
Mon Apr 10 2017 2:01pm |
Here's the how to I used .....
Mon Apr 10 2017 2:03pm |
keithdub1973 Member Since: 10 Apr 2017 Location: Dublin Posts: 11 |
cheers Jaggs ,much appreciated mate ! I'll see if I can source the parts online... |
Mon Apr 10 2017 2:38pm |
i think theres a black multi-plug on the drivers seat behind the black plastic shroud.Just make sure that is securely fixed in place wiggle it and see if anything happens as i know they have a few issues with them not properly fixed together before you spend the money,i had a problem on the passenger seat and that is what it was |
Mon Apr 10 2017 3:51pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4813 |
There are 2 horns.
Mon Apr 10 2017 6:05pm |
Geoff , Andy....cheers chaps !
Tue Apr 11 2017 7:19am |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 |
Hi Keith,
Tue Apr 11 2017 11:33am |
sound bud, i might take you up on that offer at some stage
Tue Apr 11 2017 12:52pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
Is that standard? I don't think I have (working) heaters in the drivers or passengers backrests. Merc C220 estate Sport AMG Merc C220 estate Sport AMG 125 year edition Alfa GT Rover 76 V6 |
Tue Apr 11 2017 1:24pm |
I have replaced both bulbs in the front fogs and also checked the fuse..all good but not lights working.
Tue Apr 11 2017 3:04pm |
Not heard of any sounds more like you have a failed switch or it's unplugged at the rear of switch if there is someone close to you,maybe they will let you try there switch just to see if it work's with a different switch |
Tue Apr 11 2017 3:40pm |
If they are heated on the seat squab the back rest should also be heated |
Tue Apr 11 2017 3:42pm |
It's only in the lower part of your back rest and if one fails both stop working due to the way hey are connected Nanocom Evo |
Tue Apr 11 2017 4:08pm |
Thanks for the answers.
Tue Apr 11 2017 4:43pm |
