Home > Technical > Cats or O2 Sensors need replacing?
B9BS X
EML light came on so had the codes read and the following appeared -
P0173 Fuel Trim (Bank 2) Intermittant
P0171 System Too Lean (Bank1)Historic
P0420 Catalyst System Efficincy below Threshold (Bank 1) Pending
Mechanic thinks it may need anew cat or could be just and oxygen sensor, any ideas chaps? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #521478 Mon Mar 20 2017 9:38pm
None of them are exactly solid faults.
Clear and see what come back first
Post #521496 Mon Mar 20 2017 11:04pm
B9BS X
Fuel Trim (Bank 2) fault keeps coming back after resetting faults Big Cry RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #521590 Wed Mar 22 2017 8:15am
Camelrock
Would go for the lambda sensors with that fault code 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #521593 Wed Mar 22 2017 9:24am
B9BS X
Is the lambda sensor easily accessible to change or will I need to visit my local stealer?
Also does anyone have the correct part number for a s/c lambda sensors? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #521679 Wed Mar 22 2017 6:48pm
before or after the cat ?
I assume the car has 4 ?
Post #521680 Wed Mar 22 2017 7:05pm
Camelrock
Bank 2 means the second one, bank 1 the precat 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #521759 Thu Mar 23 2017 6:07pm
thought bank 1 & 2 meant left and right
Post #521761 Thu Mar 23 2017 6:52pm
Camelrock
Quite agree Andy but often get in 4 cylinder cars with 2 lambda's and the faults are always recorded as bank 1 or 2 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #521773 Thu Mar 23 2017 10:02pm
B9BS X
Can anyone confirm the correct one to change and also the part number? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #521786 Fri Mar 24 2017 7:07am
