![]() | Home > Technical > Cats or O2 Sensors need replacing? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5096 ![]() ![]() ![]() |
None of them are exactly solid faults.
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Fuel Trim (Bank 2) fault keeps coming back after resetting faults |
Would go for the lambda sensors with that fault code 2008 G4 RRSport TDV8 current
Is the lambda sensor easily accessible to change or will I need to visit my local stealer?
before or after the cat ? I assume the car has 4 ? |
Bank 2 means the second one, bank 1 the precat 2008 G4 RRSport TDV8 current
thought bank 1 & 2 meant left and right |
Quite agree Andy but often get in 4 cylinder cars with 2 lambda's and the faults are always recorded as bank 1 or 2 2008 G4 RRSport TDV8 current
Can anyone confirm the correct one to change and also the part number? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
