Home > Maintenance & Modifications > Yet another: HDC fault, SP Off, Car lowers - Battery issue?
GSJ
Wales 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Morning All,
Apologies, im only on here when theres a problem - not very sociable Sad
Anyone advise? I'll try and summarise....
- HDC Fault warning appears on startup but on restsrt has always gone away
- On weekend changed two front tyres
- Long drive Friday/ Sat and then had HDC Fault, Special Programs Off and car lowers
If i stop, turn off and restart car all is fine, suspension goes up/ down and holds for around 30mins of driving then ping, messages pops up on dash and car lowers... turn off, on, all is well...
The car turns over well and good crank form battery. NOTE: A week ago i was working on car all day (doors, open, lights on, doors open, etc...and killed the battery, put on trickle charge overnight and turned over in morning realy well with no HDC fault...but now im having this SP Off and suspension issue... any thoughts?
Many thanks
Gareth
Post #521399 Mon Mar 20 2017 10:53am
Disco_Mikey
Need the fault codes read first Thumbs Up
Post #521400 Mon Mar 20 2017 10:57am
GSJ
Hi Disco_Mikey,
Agree - im in the process of searching this site (as we type) for advice on purchasing my own reader. I see youve commentaed previously on simular subject.
Paying an indy £80 for a diag' isnt too unreasonable but the amount of times i could have done with of these things myself, it would pay for itself.
Any recommendations sir?
kr
Gareth
Post #521401 Mon Mar 20 2017 11:03am
geoffsnook
I am in Cardiff and may be able to read them i believe it is possible with my normal IID tool Thumbs Up
Post #521402 Mon Mar 20 2017 11:06am
Disco_Mikey
IID as above Thumbs Up
Most members are happy to read fault codes for a few beer tokens. Only you can decide if it's worth spending that much money to read your own codes Thumbs Up
Post #521405 Mon Mar 20 2017 11:39am
GSJ
Thank you gents...
geoffsnook - that would be great! much appreciated. Not that it matters too much, but which direction of Cardiff are you based, N,S,E,W?
kr
Gareth
Post #521409 Mon Mar 20 2017 12:27pm
geoffsnook
Hi I am in the east of cardiff if you want to arrange something Thumbs Up
Post #521410 Mon Mar 20 2017 12:39pm
GSJ
....i'll work around your committments, but the car is going into the garage on Friday for its Front Lower Control Arms and 4 wheel alignment... would be great if we could squeeze it in before Friday... is that poss?
kr
Gareth
Post #521413 Mon Mar 20 2017 12:59pm
geoffsnook
off tomorrow if thats any good to you or later today Thumbs Up
Post #521418 Mon Mar 20 2017 1:33pm
GSJ
I've just sent a message - not tried it before, but hope it comes through..
Post #521421 Mon Mar 20 2017 1:42pm
German-wheels
I had similar issues on my SC, turned out to be a 4 wheel alignment was needed, the car basically thought I was constantly going round a corner,, in my case it was as a result of worn bushings on the lower wishbones but the tyre change could have somehow put the car out of alignment slightly.
Yours may be diffferent to mine but that could be an easy check, most places do free alignment check and if it needs sorting I only paid £50 for a 4 wheel laser alignment
Post #521566 Tue Mar 21 2017 7:15pm
GSJ
Afternoon All,
Just a quick update for closure and maybe of some help/ use to someone in the future.
After help from Geoff ( Thumbs Up ) a 4 wheel alignment, new tie bars, front control arms and anti-roll bar bushes it would appear the issue with the car lowering and 'special programs off' warning has gone away. Bow down
On a side note - it has been identified that the HDC error on car start up (HDC does actually work however) is down to the battery on its way out - so if anyone is gettign the same issue - get your battery checked before you worry too much.
So there we are.
The car now rides smoothly, no errors (for now) and is knocking free.. whohooooo
Thanks for all the support and advice
Gareth
Post #522239 Wed Mar 29 2017 12:36pm
DrRob
Power of the forum Bow down Thumbs Up Visitor from fullfatrr.com
Post #522241 Wed Mar 29 2017 12:44pm
geoffsnook
Glad your all sorted Thumbs Up
Post #522242 Wed Mar 29 2017 1:04pm
typhoo12
Mine was doing that whole HDC fault thing too, turned out the battery was done and only at 11% 😱
Post #522304 Wed Mar 29 2017 10:30pm
