![]() | Home > Maintenance & Modifications > Yet another: HDC fault, SP Off, Car lowers - Battery issue? |
Need the fault codes read first |
| GSJ Member Since: 08 Dec 2016 Location: Cardiff Posts: 36
Hi Disco_Mikey,
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
I am in Cardiff and may be able to read them i believe it is possible with my normal IID tool |
IID as above |
Thank you gents...
Hi I am in the east of cardiff if you want to arrange something |
....i'll work around your committments, but the car is going into the garage on Friday for its Front Lower Control Arms and 4 wheel alignment... would be great if we could squeeze it in before Friday... is that poss?
off tomorrow if thats any good to you or later today |
I've just sent a message - not tried it before, but hope it comes through.. |
| German-wheels Member Since: 23 Jul 2016 Location: Bournemouth Posts: 88
I had similar issues on my SC, turned out to be a 4 wheel alignment was needed, the car basically thought I was constantly going round a corner,, in my case it was as a result of worn bushings on the lower wishbones but the tyre change could have somehow put the car out of alignment slightly.
Afternoon All,
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2026
Power of the forum |
Glad your all sorted |
| typhoo12 Member Since: 10 Nov 2016 Location: United Kingdom Posts: 40
Mine was doing that whole HDC fault thing too, turned out the battery was done and only at 11% 😱 |
| All times are GMT |
