![]() | Home > Technical > Ace / Active Stabilization System |
SAS32 Member Since: 05 Feb 2017 Location: UK Posts: 27 ![]() ![]() |
It's a sealed system and thus the level won't change unless you have a leak, and you don't want to run the pump low on fluid as it's a �1k part!!
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Check the connections to the valve block, one of them may have come lose causing the incorrect pressure reading. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
You need a full code read done. There are at least 4 codes that have C1119 at the start and all relate to hydraulic pressure in the DR system.
Edmundz1 Member Since: 28 Jun 2016 Location: London Posts: 13 ![]() |
Thanks for your replies guys, still had no luck. Changed the filter and fluid as its coming out black but still no joy. Is there any software out there that i can use, at the moment I'm using wow autocar.
Sorry to be a pain, when you say full code read regarding the fault code C1119 underneath that code my software says -0. Would that relate to anything?
Fault now fixed, ended up being dirty fluid blocking the solenoid on the valve block. Flushed system with new fluid and fault now clear. |
Good news. Thanks for letting us know the outcome. One to add to the collective knowledge. |
