![]() | Home > Maintenance & Modifications > Can someone help with my Range Rover suspension issue |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
It looks like the air bag on the offside rear has an air leak. Either that or a sticky valve in the rear air block.
German-wheels Member Since: 23 Jul 2016 Location: Bournemouth Posts: 88 ![]() ![]() ![]() |
Thought as much, are the bags not covered by a metal sleeve? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9133 ![]() ![]() ![]() |
Most likely valve block or damaged pipe. The air bags are pretty reliable and don't seem to be prone to failures.
They are, but with the soapy water and a good soaking you should cover all areas including the local pipes. I agree with RRSTDV8, pulling the fuse for the suspension will help to narrow down the fault. |
Thanks, I'll try the fuse! I did notice that the other rear has a new looking green hose coming from the top but this side has an old looking black one, maybe one side has been replaced already due to this.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
No database information is available in ignition pos I so the first screen can be ignored.
I think it's fuse 26 in the fuse box next to the battery (not the one behind the glovebox). It's a 20A fuse I think. 2012 SDV6 - it's missing a couple of cylinders
What don't you understand about the screen? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
So... never noticed any ride height difference when using the car, only in the morning.
For info to measure you put into off road and then drop to normal.
Ah okay, I'll do that and re-measure |
Pulling the fuse will tell you if it's an air leak or the sensor on that corner trying to auto level the car. |
I have pulled the fuse so will find out soon, Is it normal that it was pulled while in normal height, when the fuse is reinserted the car lowers to access mode without touching the switch. |
You'll need to leave the fuse out over night. I wouldn't read too much into it lowering.
