Home > Maintenance & Modifications > Can someone help with my Range Rover suspension issue
German-wheels
Hi all,
I've noticed that the driver side rear suspension drops overnight, it goes right down to what I assume is the bump stop, the tyre tucks under the arch. It does this in both access mode and normal height, last night I left it in normal mode and came to it this morning and it was bent right over on that corner. Unlocked it and key to position 1, checked the 4x4 info and saw the below (wheels were straight so not sure why it said I was turned)
Put key to position 2 and the screen changed to the below
Started the car and the rear went to normal height, and the screen showed correct heights.
Can anyone shed some light on the screenshots above, I'm assuming the air suspension is leaking in that corner.
Post #520537 Fri Mar 10 2017 12:20pm
Socast
It looks like the air bag on the offside rear has an air leak. Either that or a sticky valve in the rear air block.
Make up a bucket of soapy water (plenty of fairy, but try to keep bubbles to a minimum), put the car in off-road height and throw the soapy water over the rear strut and watch for bubbles.
Post #520541 Fri Mar 10 2017 1:22pm
German-wheels
Thought as much, are the bags not covered by a metal sleeve?
Post #520543 Fri Mar 10 2017 1:36pm
Most likely valve block or damaged pipe. The air bags are pretty reliable and don't seem to be prone to failures.
First step is to disable the air suspension overnight by pulling the relevant fuse. If it still drops then it's a leak. If it stays up then it's probably the sensor. 2012 SDV6 - it's missing a couple of cylinders
Post #520549 Fri Mar 10 2017 2:37pm
Socast
They are, but with the soapy water and a good soaking you should cover all areas including the local pipes.
I agree with RRSTDV8, pulling the fuse for the suspension will help to narrow down the fault.
Post #520550 Fri Mar 10 2017 3:06pm
German-wheels
Thanks, I'll try the fuse! I did notice that the other rear has a new looking green hose coming from the top but this side has an old looking black one, maybe one side has been replaced already due to this.
Any idea which fuse number it is?
Thanks again!
Post #520554 Fri Mar 10 2017 3:22pm
No database information is available in ignition pos I so the first screen can be ignored.
The 2nd screen does show that wheel up. (one day I might understand that screen!)
Its normal for a pipe to be an odd colour from the factory (orange or green). Helps with identification.
I don't see the point in removing a fuse in this case, It's very clear which corner has the problem,
Post #520559 Fri Mar 10 2017 4:22pm
I think it's fuse 26 in the fuse box next to the battery (not the one behind the glovebox). It's a 20A fuse I think. 2012 SDV6 - it's missing a couple of cylinders
Post #520560 Fri Mar 10 2017 4:22pm
What don't you understand about the screen? 2012 SDV6 - it's missing a couple of cylinders
Post #520561 Fri Mar 10 2017 4:24pm
German-wheels
So... never noticed any ride height difference when using the car, only in the morning.
Just looked at it and the driver side does appear to sit a bit lower than the passenger. Measured all 4 corners in normal height (from arch to bottom of alloy not including tyre) and results below.
Osf- 74cm
Nsf- 76.5cm
Osr- 75cm
Nsr- 72.5cm
I assume the NSF is adjusting due to the rear being incorrect. But this does suggest that its not just dropping but also not sitting level at any point
Post #520567 Fri Mar 10 2017 5:30pm
For info to measure you put into off road and then drop to normal.
Best to have the handbrake off if you can and be on level ground
Measure from lip to wheel Center.
Post #520569 Fri Mar 10 2017 6:25pm
German-wheels
Ah okay, I'll do that and re-measure
Post #520570 Fri Mar 10 2017 6:35pm
Socast
Pulling the fuse will tell you if it's an air leak or the sensor on that corner trying to auto level the car.
Post #520583 Fri Mar 10 2017 8:25pm
German-wheels
I have pulled the fuse so will find out soon, Is it normal that it was pulled while in normal height, when the fuse is reinserted the car lowers to access mode without touching the switch.
Post #520584 Fri Mar 10 2017 8:36pm
Socast
You'll need to leave the fuse out over night. I wouldn't read too much into it lowering.
I forgot to mention, rather than pulling the fuse you could have disconnected the battery (bit quicker and easier).
Post #520585 Fri Mar 10 2017 8:40pm
