![]() | Home > General > Squirrel |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 ![]() ![]() ![]() |
Went out to the car this morning, had not used it for a week, and had suspension fault pop up.
Battery should be good, it is on a Ctek when not being used.
Not a squirrel but one of his mates, customers D3 with a fuel leak. Dropped the tank and..........
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5136 ![]() ![]() ![]() |
You wouldn't think they would like the taste of diesel |
Years ago I had a Volvo 480ES (most unreliable car I have ever owned). I was able to get it inside my garage and I went off to sea for 7 months................. those were the days when I could go away that long and the car's battery was not dead when I came home!
Well I put the IID in and got the following faults.ARCM-Active Roll
Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98 ![]() ![]() ![]() |
I would say that the front left height sensor wiring has been chewed probably as Tim said on the way up and that is causing the other code as a direct result of the fault with the height sensor. Clickadeeclick |
Yes seems likely the height sensor has been chewed but I would like to know what the rubber tube is that the bloody squirrel has eaten that runs across the top of the rad, I presume that has something to do with the active roll fault. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Just an update,
