![]() | Home > General > Auxiliary Heater |
Hutch41 Member Since: 19 Nov 2016 Location: Northumberland Posts: 95 ![]() ![]() ![]() |
Can someone answer this please......there is an auxiliary heater fitted to my car.
Not sure if this applies to the later model such as yours but certainly on the models up to 2009 a snowflake appears on the dash adjacent to the temperature to indicate it is sufficiently cold to invoke operation of the auxiliary heater.
radders1 Member Since: 22 Nov 2016 Location: Preston Posts: 12 ![]() ![]() ![]() |
Being one of those 'new Range Rover owners' ![]() ![]() |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 ![]() ![]() |
http://www.disco4.com/forum/webasto-fuel-b...b999387d89 Visitor from fullfatrr.com
Thanks to everyone again.....very helpful bunch I must say. |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 ![]() ![]() ![]() |
Unless I'm mistaken, the snowflake indicates that the temperature is low enough for a risk of ice, rather than that the heater has come on. Of course, they may both be triggered by the same temperature but I think the first reason is more useful. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4823 ![]() ![]() ![]() |
Absolutely.
RallyXS Member Since: 07 Oct 2016 Location: Devon Posts: 82 ![]() ![]() |
When I read the manual I'm sure it said the FBH would activate below 8c. 2012 RRS SDV6
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8880 ![]() ![]() ![]() |
FBH activates at external temperature below 9deg C and with a coolant temp below 75deg C. 2012 SDV6 - it's missing a couple of cylinders
Ha Ha.
actually.... it's 5degrees....... |
I got it from the Workshop Manual... |
Just to resurrect this and show how nerdy some of us are, I read that the FBH won't activate if you have less than 1/4 tank of diesel. Well I was nearly down to reserve and mine worked, so that must be a myth. 2012 RRS SDV6 2014 BMW 320d X-Drive Touring 1999 VW Polo stage rally car |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 ![]() ![]() ![]() |
I've heard that if you have a pink one it's 9 degrees, but if it's a blue one, it's 8 degrees.
