Home > Maintenance & Modifications > steering
my 1st sport
United Kingdom 2013 Range Rover Sport Supercharged Orkney Grey
steering
Hi
Just let my girlfriend drive my rrs from the the pub and she says the steering is very strange either pulling left or right. Nearly made me sick going from side to side. I did the two front lower wishbone and roll bar bushes last year its got dsc being the supercharged i must admit it does seem to pull a bit when the camber of the road is a bit steep.i had all the tracking done on a 4 wheel alignment computer at the local chemex. i have nothing to compare it to because after driving my vivaro all week it feels like a rocket ship my other half drives 2.0sri astra which feels like a go cart to me. so is this normal for a car with wide tires.any help would great thanks
Post #514586 Sun Jan 15 2017 6:27pm
Tim in Scotland
Which wheels and tyres are you running on? Your car had the heavy duty steering rack as original equipment as S/C's and NA V8's were delivered from the factory on 20" rims and tyres whereas the lesser spec cars needed a steering rack upgrade for 2005 and 2006MY cars to run 20" wheels........ but if you are running 22" wheels and tyres then you may have a worn steering rack as the car was never designed to run on such extreme size wheels. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #514588 Sun Jan 15 2017 6:32pm
my 1st sport
wheel size
Hi Tim
its got standard 20" wheels with good tires.
Post #514589 Sun Jan 15 2017 6:41pm
Tim in Scotland
1st I'm not a mechanic or engineer so thinking of other things that you could check - when was the power steering fluid last changed/ checked/topped up, have you noticed any leaks/ oily marks on the drive under the front of the car that could be a leak causing low hydraulic fluid for the steering or any hissing noises when you turn to full lock? The system is usually silent. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #514591 Sun Jan 15 2017 6:49pm
my 1st sport
steering
no nothing like that.
Post #514592 Sun Jan 15 2017 6:53pm
Disco_Mikey
Does the steering feel heavy or notchy when turning?
Lower steering column can cause weird steering issues
Post #514605 Sun Jan 15 2017 8:53pm
DrRob
Alltrack 4x4 in Malvern are rated Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #514610 Sun Jan 15 2017 8:59pm
my 1st sport
steering
no its not notchy and its nice and light.
Post #514616 Sun Jan 15 2017 9:10pm
Black Bess
It may just be the brand of tyres that you have, which are tending to follow the road camber. You could experiment a bit with pressures. I like to run 40-45 psi in mine.
If you find it ok, then the answer may just be to always drive yourself!
Failing that, you could add just a little extra toe-in at the front to make it less nervous over bumps. But it does sound like a question of driver familiarity.
Post #514657 Mon Jan 16 2017 11:41am
Russben
Might be worth checking where the wheel balance weights are fixed too. I once had a Jag that the local tyre depot stuck all the weights on the innermost edge of the wheel and the gyroscopic effect made the steering very weird. It drove straight until you started to turn a corner or bend and then the steering wanted to keep on turning that way and was difficult to turn back again. Needless to say I went straight back with it and once the experienced fitter saw what the trainee had done they corrected it without any further issues. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #514658 Mon Jan 16 2017 12:22pm
Black Bess
Interesting !! I hadn`t heard of that one before.
Post #514660 Mon Jan 16 2017 12:34pm
Russben
Apparently the weights should ideally be fitted level with the hub face. Makes sense really 'cos if all the weight is on the inner edge it is probably a good 6 inches or more away from the centre line of the wheel and the gyroscope effect will have an influence. Certainly did on my Jag and that didn't have wheels as wide as the RRS. I'm in the shed, I'll be back in the real world in a minute.
Post #514663 Mon Jan 16 2017 12:50pm
Black Bess
Yes, it does make sense actually. Just hadn`t given it much thought.
Post #514665 Mon Jan 16 2017 1:00pm
