Home > Maintenance & Modifications > battery problems??
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Silly question but how do I tell when or if the FBH is operating? RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #514469 Sat Jan 14 2017 8:15pm
PEACHY
^^^^^read the owners handbook^^^^^ Rolling with laughter Rolling with laughter
Do you have the small plipper remote ? If not you have too set it manually via the infotainment screen Thumbs Up
When it starts it whistles followed by ignition & the obvious sound of a heater whirling away - there is also fumes omitted Thumbs Up 16MY Estoril Blue SVR.............
Post #514470 Sat Jan 14 2017 8:19pm
riverblanche
Although the FBH should check fuel level and battery good before running, it does not always get it right Rolling Eyes
Early Last year I used the remote for the FBH on my way out to work as swmbo was going out in half an hour,
about half an hour later I got a call from her "the car wont start the battery is flat" Censored one cell was bad and running the FBH was enough to kill it.
New Exide AGM fitted and BCM updated Thumbs Up
roll on to last month and the FBH was trying to fire but not running to full burn (no mistaking the sound of the FBH its like a mini jet engine Laughing ) I understood that it can "lock out" after 5 failed attempts, but mine had failed more than that and was still trying.
happy to report covered by warranty and new FBH now fitted
Post #514471 Sat Jan 14 2017 8:35pm
Wayneclarke
Locks out due to low voltage or low fuel
Post #514472 Sat Jan 14 2017 8:35pm
riverblanche
it will check that both are ok (think its 1/4 tank of fuel) if either is not correct it will not try to run but not Lock out that's if it tries to run but fails
Post #514475 Sat Jan 14 2017 8:41pm
PEACHY
Everyone's outside now checking there FBH Whistle
Just checked mine - whining away like a good un Laughing
Thanks Gents Thumbs Up 16MY Estoril Blue SVR.............
Post #514476 Sat Jan 14 2017 8:43pm
LG8340
I don't have a remote so apart from listening for a whining sound there is no way of knowing if my FBH is do it's job?
How sad is that? RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #514477 Sat Jan 14 2017 8:47pm
PEACHY
Agree it's a bit Censored - have you ever set it up via the info screen ? 16MY Estoril Blue SVR.............
Post #514478 Sat Jan 14 2017 8:49pm
Can't you just start the car and let it run for 1 minute.
Switch engine off and go round the front.
You should hear it cooling down.
Well that's how it is in the early models
Post #514479 Sat Jan 14 2017 8:51pm
LG8340
No I haven't come across that yet. I'll have to give it a try tomorrow.
Thanks for the heads up. RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #514484 Sat Jan 14 2017 9:38pm
Johnski
Don't have mine shown on info screen, (no facility to put it there with IID BT Tool, that I can find?) or remote operation, it just comes on automatically if temperature is 5c or lower, runs I assume for preset time or until temperature of engine has risen.
Another quite obvious sign of FBH running is the smoke coming out from passenger side wheelarch and bonnet.
Been told before now my car is on fire. Whistle John
Post #514597 Sun Jan 15 2017 7:31pm
