Home > Maintenance & Modifications > battery problems??
Wayneclarke
battery problems??
Ive noticed that my FBH has stopped working after Bodsy sorting it for me ages ago, I've never let the fuel go low so only thing i can think is low voltage, just had my Bosch S5 Battery tested with an analyser and the cca is only reading 603 when the battery is 830cca. and also says the the battery needs charging when before testing i had been driving the car for about an hour.
does that mean the voltage would drop when turning over in the cold weather enough to lock out the FBH ???
Do i need a new battery?
Post #514428 Sat Jan 14 2017 12:55pm
I would have thought you would have other dash error messages when you start the engine if the battery was low. These are usually the first signs.
Post #514430 Sat Jan 14 2017 1:36pm
Wayneclarke
yeah i replaced the battery in 2015 because of these problems so i replaced it then my alternator fried so i think maybe the battery took a bit of a whack, the navigation reboots at the moment but no other signs but the FBH locking out i think is due to low voltage
Post #514431 Sat Jan 14 2017 1:41pm
PEACHY
I Had the same kind of issue - booked it in for the FBH to be checked under warranty - the battery was the issue & I had no other error codes at all on the dash. I did trickle charge the battery using my CTek but even that didn't give the charge needed for the FBH. Big Cry
New battery fitted - issue sorted. Thumbs Up 16MY Estoril Blue SVR.............
Post #514432 Sat Jan 14 2017 1:41pm
Wayneclarke
yeah snap mate i use a ctek charger at least once a month due to short journeys, but it doesn't seem to be working i think the alternator has killed it a little bit, What battery did you replace it with ??? I'm looking at this one http://www.eurocarparts.com/ecp/p/car-batt...mp;cc5_999
Post #514433 Sat Jan 14 2017 1:46pm
PEACHY
I let the dealership put it on - I just handed over my hard earned cash Big Cry it wasn't cheap but the wife offered to pay Whistle 16MY Estoril Blue SVR.............
Post #514435 Sat Jan 14 2017 1:50pm
Wayneclarke
ha ha lucky man
Post #514436 Sat Jan 14 2017 1:51pm
PEACHY
Wasn't that lucky - a few weeks later I part exchanged it in for my current Sport - it was an impulse thing - Mrs hasn't let me forget it Rolling with laughter Rolling with laughter 16MY Estoril Blue SVR.............
Post #514437 Sat Jan 14 2017 1:55pm
donny dog
Pardon my ignorance, but what is an 'FBH'?
Post #514438 Sat Jan 14 2017 2:25pm
Wayneclarke
fuel burning heater
Post #514439 Sat Jan 14 2017 2:27pm
donny dog
Aaaaaah.....thanks!!
Post #514440 Sat Jan 14 2017 2:28pm
Wayneclarke
well quick update i went and bought a new battery
Post #514459 Sat Jan 14 2017 7:38pm
PEACHY
Did it do Wink the trick 16MY Estoril Blue SVR.............
Post #514461 Sat Jan 14 2017 7:52pm
Wayneclarke
I haven't had the FBH unlocked yet but will soon find out once I have done if it locks out again
Post #514467 Sat Jan 14 2017 8:08pm
PEACHY
Never knew it locked out - how does that happen ? 16MY Estoril Blue SVR.............
Post #514468 Sat Jan 14 2017 8:13pm
