![]() | Home > Faults & Fixes > Slight knock when braking at slow speeds or applying brakes |
Front lower arm sus bushes. 2008 G4 RRSport TDV8 current
Rob199026 Member Since: 02 Jan 2017 Location: Essex Posts: 39 ![]() ![]() |
Oh lovely expensive job ?? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
Bushes can be replaced but the bolts usually seize so the arms are best just cut off. That means new arms, unfortunately, but is usually cheaper than paying a man to spend hours getting the bolts out.
Great !! Thanks for help going in for her mot on Monday so will probably fail ! |
Probably won't. The bushes make a noise but still "work" so likely not to be picked up. Fingers crossed, anyway! 2012 SDV6 - it's missing a couple of cylinders
