Home > Technical > 'Check Spare Tyre Pressure' message
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
For last few days I am getting 'Check Spare Tyre Pressure' message with a yellow ring, checked the pressure of the spare and its on 34. Could it be an issue with the sensor unit? one way would be to swap the spare with one of the running wheels and then drive for 15 min and to check the pressure to see what it reports, still lot of work getting the wheel out as its so heavy.
Wondering if Anyone else had similar issue.
Post #512652 Tue Dec 20 2016 10:18am
Tim in Scotland
Sounds like you haven't had the TSB applied to your car that retro-fits the missing spare wheel lifter? If you have any warranty left it might be time to get it looked at using that. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512653 Tue Dec 20 2016 10:21am
udash
Tim, I got the wheel lifter tool, have not tried it yet. I got 2 years warranty left and as its only a warning I could ask the dealer to have a look when its in for a software update, I got two pending at the moment. Would have been so much easier if the system displayed spare wheel pressures alone with the other wheels.
Post #512656 Tue Dec 20 2016 11:30am
Tyrefitter
if its a space saver wheel you have for a spare they have about 60psi in them.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #512657 Tue Dec 20 2016 12:38pm
Tim in Scotland
Does the TMPS not show the tyre pressure for the spare then. I can read the pressures of all my tyres in the dash in 2015MY HSE D 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512668 Tue Dec 20 2016 2:29pm
udash
Andy,
its a full size wheel (from factory with the TPM sensor).
Tim,
Could MY16 has reduced functionality or issue with mine as mine shows only the running wheels from day 1. Could someone with MY16 and TPMS confirm if you could see the spare pressure or not please.
According to the workshop manual warning comes when spare pressure goes down by 20%.
Post #512671 Tue Dec 20 2016 3:07pm
Tyrefitter
Mine 2014 AB only gives a reading for 4 tyres,,,,it could be something to do with it being a 7 seater & I don't have a spare Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #512672 Tue Dec 20 2016 3:20pm
Tim in Scotland
Just been out and checked mine - only the four running wheels too, apologies. I have space saver spare that has a plain black valve in it the others all have silvery grey valve stems and caps 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #512673 Tue Dec 20 2016 3:43pm
udash
Thanks Tim and Andy, well at least all our RRSs have same functionality Smile
I booked in with the dealer, they are so busy, first available appointment is in early Feb.
Post #512688 Tue Dec 20 2016 7:33pm
scrumps
We've just had TPMS warnings on both my RRS AB and SWMBO's D4.
I check the pressures regularly with a trusted gauge.
When checked, ALL pressures were down by 3-4 psi, then I realised it was ***kin cold - so the pressures had dropped.
All pressures topped up ( with cold fingers) - all warnings.....gone.
As there is nowhere I can find for the spare pressure I gave them 40psi especially on the D4 as winching it down is a reall pain.
Try it !
Scrumps. Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - šŸ˜€
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #512710 Wed Dec 21 2016 10:59am
jonathana13
Did you manage to get this sorted? Or has anyone else had the issue? Mine started prompting to let me know it's low but it doesn't tell you what it should be! Have tried putting 40psi in but it's still giving the error. Any ideas?
Post #564317 Sat Sep 01 2018 7:04pm
Brit Plumber
Had similar issues in the past and never resolved them but always thought it was interference as it would disappear. Do you have any electronic devices in the back or fitted a camera or anything like that? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #564321 Sat Sep 01 2018 7:49pm
jonathana13
Thanks, it does seam like interference but seams to do it each startup, was fine the day I picked the car up, but does it on each startup now. Haven't had a chance to get it to a dealer as not dealing with my local franchise anymore so will have to make a trip of it.
Post #564322 Sat Sep 01 2018 7:58pm
jonathana13
Good news (hopefully) I spoke to Team Valley LR who advised it could just be the pressure is too low (I know shocking right)
They said they normally put 50psi in a spare so tried that and so far no warning. Couldn't find that in the manual anywhere so hope it could be useful to others.
Post #564668 Thu Sep 06 2018 8:19pm
Tyrefitter
I have a full size spare in my Sc,I’m going to let some air out of it tomorrow & see if I get a message on dash.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #564669 Thu Sep 06 2018 8:21pm
