![]() | Home > Technical > 'Check Spare Tyre Pressure' message |
Sounds like you haven't had the TSB applied to your car that retro-fits the missing spare wheel lifter? If you have any warranty left it might be time to get it looked at using that. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
Tim, I got the wheel lifter tool, have not tried it yet. I got 2 years warranty left and as its only a warning I could ask the dealer to have a look when its in for a software update, I got two pending at the moment. Would have been so much easier if the system displayed spare wheel pressures alone with the other wheels. |
if its a space saver wheel you have for a spare they have about 60psi in them.
Does the TMPS not show the tyre pressure for the spare then. I can read the pressures of all my tyres in the dash in 2015MY HSE D 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Andy,
Mine 2014 AB only gives a reading for 4 tyres,,,,it could be something to do with it being a 7 seater & I don't have a spare |
Just been out and checked mine - only the four running wheels too, apologies. I have space saver spare that has a plain black valve in it the others all have silvery grey valve stems and caps 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks Tim and Andy, well at least all our RRSs have same functionality |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 560 ![]() ![]() |
jonathana13 Member Since: 23 Dec 2017 Location: North East Posts: 172 ![]() ![]() |
Did you manage to get this sorted? Or has anyone else had the issue? Mine started prompting to let me know it's low but it doesn't tell you what it should be! Have tried putting 40psi in but it's still giving the error. Any ideas? |
Had similar issues in the past and never resolved them but always thought it was interference as it would disappear. Do you have any electronic devices in the back or fitted a camera or anything like that? 2019 5.0 SC SVA (Current)
Thanks, it does seam like interference but seams to do it each startup, was fine the day I picked the car up, but does it on each startup now. Haven't had a chance to get it to a dealer as not dealing with my local franchise anymore so will have to make a trip of it. |
Good news (hopefully) I spoke to Team Valley LR who advised it could just be the pressure is too low (I know shocking right)
I have a full size spare in my Sc,Iām going to let some air out of it tomorrow & see if I get a message on dash.
