Home > In Car Electronics > Radio satnav fault
Plazmapete
Radio satnav fault
Hi recently purchased a range rover sport. Nice car. But having a few problems with it. If anyone can help it would be much appreciated.
Every morning when I start the car the radio and satnav keep going off for about 20 seconds. Although today it was fine. Don't know if it was because it was a nice warm day. Any thoughts??
Post #497895 Sun Jun 05 2016 4:25pm
Down&Dirty
Probably be good to get a test meter on it 1st thing in the morning before starting it and see what condition the battery is in. Thumbs Up Currently MY16 Disco 4 Mr. Green
Ex RRS MY13
Ex Discovery 3 MY08
Post #497898 Sun Jun 05 2016 5:03pm
Plazmapete
Thanks for the reply. Had the aircon re-gased last week are they tested battery while I was there and the machine said battery was OK.
Post #497899 Sun Jun 05 2016 5:10pm
Down&Dirty
Ok,was it a proper load tester?
If not would be worth testing it after its been stood for 12+hrs Thumbs Up Currently MY16 Disco 4 Mr. Green
Ex RRS MY13
Ex Discovery 3 MY08
Post #497900 Sun Jun 05 2016 5:13pm
Plazmapete
Think so. Kwik fit. It wad some bosch computerised thing.
Post #497904 Sun Jun 05 2016 5:48pm
Down&Dirty
Just seen your other post,think you made need your fault codes read to see what's going on. Very Happy Currently MY16 Disco 4 Mr. Green
Ex RRS MY13
Ex Discovery 3 MY08
Post #497906 Sun Jun 05 2016 6:21pm
Plazmapete
Will get it looked at next week. When I first got the car I had I checked. No faults were found. Although the garage said the diagnostic machine said it's needs the radio unit updating or something along those lines.
Post #497908 Sun Jun 05 2016 6:35pm
Plazmapete
Requires module update. It will work fine all day. Just plays up in the morning.
Post #497909 Sun Jun 05 2016 6:38pm
Plazmapete
UPDATE.
Purchased a voltage reader you can put into the cigarette lighter. This morning it read over 16 volts for a few mins then settles around 14 volts. Got it booked in next week for new alternator.
Post #512417 Fri Dec 16 2016 5:36pm
Johnski
Don't just rush in purchasing a new Alternator, the voltages are not too bad, were they taken under load, engine running? If you have certain items running can effect rate, battery can read OK, but still be lower than at new, and on its way out after four years.
First thing I would do is get the codes checked for any problems using a proper tool for testing such as the GAP IID BT tool,
or at a JLR dealership. John
Post #512436 Fri Dec 16 2016 8:21pm
Plazmapete
If I switch both heated screens on, the satnav and radio work fine.
Radio and satnav will work fine with engine off. When I start it the voltage shoots up to 16 + volts. Once it's run for a few mins it's fine all day. Been told anything over 14 volts will cook the battery.
Post #512442 Fri Dec 16 2016 9:17pm
donny dog
Obviously the load settles the voltage down. Is there a voltage regulator that is separate to the alternator which could be changed to avoid the cost of a complete alternator?
Post #512443 Fri Dec 16 2016 9:22pm
Plazmapete
I thought it was all one unit.
Post #512446 Fri Dec 16 2016 10:48pm
donny dog
It may well be, I was just asking the question in case it was an option.
Post #512447 Fri Dec 16 2016 10:51pm
Plazmapete
Is the voltage regulator part of the alternator or is it separate????
Post #512499 Sat Dec 17 2016 5:57pm
