![]() | Home > In Car Electronics > Radio satnav fault |
Down&Dirty Member Since: 31 Dec 2015 Location: Somewhere out back Posts: 92 ![]() ![]() |
Probably be good to get a test meter on it 1st thing in the morning before starting it and see what condition the battery is in. |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 ![]() ![]() ![]() |
Thanks for the reply. Had the aircon re-gased last week are they tested battery while I was there and the machine said battery was OK. |
Ok,was it a proper load tester?
Think so. Kwik fit. It wad some bosch computerised thing. |
Just seen your other post,think you made need your fault codes read to see what's going on. |
Will get it looked at next week. When I first got the car I had I checked. No faults were found. Although the garage said the diagnostic machine said it's needs the radio unit updating or something along those lines. |
Requires module update. It will work fine all day. Just plays up in the morning. |
UPDATE.
Don't just rush in purchasing a new Alternator, the voltages are not too bad, were they taken under load, engine running? If you have certain items running can effect rate, battery can read OK, but still be lower than at new, and on its way out after four years.
If I switch both heated screens on, the satnav and radio work fine.
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Obviously the load settles the voltage down. Is there a voltage regulator that is separate to the alternator which could be changed to avoid the cost of a complete alternator? |
I thought it was all one unit. |
It may well be, I was just asking the question in case it was an option. |
Is the voltage regulator part of the alternator or is it separate???? |
