![]() | Home > General > Bouncy/boat like ride |
Can you have a look under both sides at the back and see if there are two large sliding steel weights hanging there? It isn't unknown for them to be removed to try and lighten the car but they are an important part of the suspension set up - they are used as harmonic dampers I believe. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2024 ![]() ![]() |
In Dundee you have access to a guru independent LR mechanic - MMP Land Rovers. He's Disco Mikey on here... * Current: 2024 D350 Defender 90 on coils!
n16mct Member Since: 27 Oct 2016 Location: Scottish Borders Posts: 6 ![]() ![]() ![]() |
Ive Had a look and the weights appear to be there! Dundee is about 2 1/2 hours from us, not end of the world but hoping to do some of the basic stuff here before thinking along those lines, more than happy to go up there if need be though! thanks for your help! any other ideas? |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Go to a stealer and test drive a similar model to make sure your particular car actually has an issue. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
If you're in the AA/RAC then call them out and get them to plug their diagnostic in |
Charliecloud Member Since: 21 Oct 2016 Location: Tonbridge Posts: 23 ![]() ![]() |
What wheels and tyres are you using? |
A couple of quickies you most probably already tried.
Thanks to everyone for all the suggestions!
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
I had similar issues to you in that my ride was very hard and feeling all bumps and potholes. I recalibrated my suspension, and all is fine now. I think the ride should be smooth but slightly firm (a downside of having low profile tyres on a 2.5 tonne 4*4).
Finn mc Missile Member Since: 13 May 2016 Location: Home Posts: 16 ![]() ![]() ![]() |
Poelpetater Member Since: 18 Apr 2022 Location: Western Cape Posts: 1 ![]() ![]() |
I know this was posted a long time ago, but did you ever get to the bottom of this issue? |
