Home > General > Bouncy/boat like ride
n16mct
Scotland 2005 Range Rover Sport TDV6 HSE Java Black
Hello there Im new to the forums, used the site a few times now some really useful info on here!
I was wondering if anyone could shed some light- Ive bought my first rrs, I love it, 2005, done a high mileage but been well maintained according to the history, I love the look of it, but to be honest I'm hating the ride, its like a boat, very bouncy, you feel every bump, Ive only really owned bmw coupes before so I presumed this was maybe normal to start with, being such a big car with air suspension, however the more I'm driving it the more I'm sure its not right, Im in the motortrade so i have driven a lot of cars to compare, but never owned a 4x4 before, Ive had a local mechanic have a quick look at it, the shock absorbers don't seem to be leaking they are bone dry, the rear suspension does seem to sit a list lower compared to the front, I could maybe get a photo up here tomorrow, the bags don't seem to be leaking but i don't want to go and just slap new suspension on it for the sake of it
Anyone had anything similar? or any common problems that might cause this? Its had a new suspension compressor in the past so hopefully ruled that out! no fault codes stored! seems to be mechanical rather than electrical!
Many thanks
Nick
Post #508801 Thu Oct 27 2016 7:17pm
Tim in Scotland
Can you have a look under both sides at the back and see if there are two large sliding steel weights hanging there? It isn't unknown for them to be removed to try and lighten the car but they are an important part of the suspension set up - they are used as harmonic dampers I believe. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #508811 Thu Oct 27 2016 9:18pm
DrRob
In Dundee you have access to a guru independent LR mechanic - MMP Land Rovers. He's Disco Mikey on here... * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #508822 Fri Oct 28 2016 1:59am
n16mct
Ive Had a look and the weights appear to be there! Dundee is about 2 1/2 hours from us, not end of the world but hoping to do some of the basic stuff here before thinking along those lines, more than happy to go up there if need be though! thanks for your help! any other ideas?
Post #508883 Fri Oct 28 2016 11:21pm
ilard
Go to a stealer and test drive a similar model to make sure your particular car actually has an issue. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #509045 Mon Oct 31 2016 10:51pm
DrRob
If you're in the AA/RAC then call them out and get them to plug their diagnostic in Thumbs Up * Current: 2024 D350 Defender 90 on coils!
Post #509081 Tue Nov 01 2016 1:04pm
Charliecloud
What wheels and tyres are you using?
Post #509092 Tue Nov 01 2016 3:31pm
Johnski
A couple of quickies you most probably already tried.
Check the air pressures in all the tyres against the ratings on drivers door relevant to loading. Check there is no damage or bulges to inside/outside of tyres, no mixed sizes (does happen).
If you have "Dynamic" drive facility fitted in your car, (part of 4x4 option selectable programs) this will tighten the suspension and become more of a drivers car with other additions depending on model spec. Switch this on and go for a test drive over various types of road and see if it vastly improves.
Please keep us all in the picture as you proceed.
Disco Mikey IMO would be an excellent Indy person to visit if you cannot find anything wrong. (Who is Reasonably priced) give him a ring for other check suggestions.
If you own/have access to a Gap Diagnostic IID BT tool this would show any fault codes, but will also show what all the heights of the various wheels/suspension is set at, for Off Road, Normal and Access, and these can be adjusted as required. John
Post #509122 Tue Nov 01 2016 11:37pm
n16mct
Thanks to everyone for all the suggestions!
wee update - got speaking to a local indy that specialises in land rovers but mostly older ones, however he has the diagnosic equipment for the air suspension, plugged it in and discovered a few of the ride height sensors have a poor connection, must be a common problem with them! the NSF was 7mm too high, OSR 2mm too low and NSR 3mm too low, he reset them to facory heights and the car drove a lot better, however having had it in access mode since he reset it, the car has returned to driving terribly, Its going in next week to have the faulty sensors/wiring attended to! hopefully this will fix it e are pretty confident!
I will update once its gone in! Fingers crossed!!
Post #509179 Wed Nov 02 2016 8:40pm
Stecla
England 2010 Range Rover Sport TDV8 HSE Stornoway Grey
I had similar issues to you in that my ride was very hard and feeling all bumps and potholes. I recalibrated my suspension, and all is fine now. I think the ride should be smooth but slightly firm (a downside of having low profile tyres on a 2.5 tonne 4*4).
If you are outside of dynamic mode, I think it would be normal for the car to wallow a bit as it can't defy the laws of physics. Do you know anyone near you with a rrs? If so, maybe worth going out for a ride to compare but keep trying. Mine took 4 months to get right, but when they are they are great machines.... 2010 TDV8
Post #509206 Thu Nov 03 2016 8:27am
Finn mc Missile
Finland 2006 Range Rover Sport TDV6 SE Zermatt Silver
I had a similar feeling with my MY06 RRS. Didn't like at all how it felt over the bumps. However, here in Finland they check shocks on test bench in MOT and I knew that rear ones are almost gone. I replaced them and bingo! Feeling between old and new ones is more than night and day. Love the ride now, totally different Thumbs Up
My schocks were totally dry, no leaks, but they were dead anyway. Old spring-shock combination on my hand, tried to push it in, no resistance at all at first 3-4 inches. No wonder why it felt terrible.
Fairly easy job to replace them by yourself.
Post #510007 Mon Nov 14 2016 5:34am
Poelpetater
South Africa
I know this was posted a long time ago, but did you ever get to the bottom of this issue?
Post #623646 Mon Apr 18 2022 5:52am
