Home > Group Buys > TDV8 Decat downpipes
Sign Up
(2)
User Registered Confirmed
PaddiSun Nov 06 2016 11:38am
ShooterNeilMon Jul 24 2017 10:53pm
Disco_Mikey
Currently in discussion with a local exhaust specialist, about producing some stainless steel decat downpipes for the 3.6 TDV8. I can't find anyone producing an off-the-shelf pair of decat downpipes anywhere, unless anyone's knows better, and can point me in said direction Thumbs Up
Prices are yet TBC, and will be a direct replacement, requiring no further modifications. Will have a better idea of price once he has my pipes as a template, jig produced and for test fitting etc. Obviously, the more they manufacture, the cheaper the price will be
This thread is purely to gauge demand Thumbs Up
Post #509345 Fri Nov 04 2016 9:17pm
Paddi
Ooh that's a bit tempting. So just to cover the likely questions that people may have:
Can you confirm there should be no problem with MOT as cats are not compulsory for diesels?
Should there be a small increase in performance owing to less back pressure?
Main improvement would be a more satisfying exhaust note?
Thanks. 2008 MY Java Black TDV8 HSE
Post #509422 Sun Nov 06 2016 11:44am
Disco_Mikey
Cats should be visibly present for an MOT. Dummy cats will be in place to satisfy this MOT requirement
Don't expect massive gains in performance, but a little less turbo lag and a little more bottom end power are likely
It will be a little noisier, as the cat does act as a silencer. But again, not hugely so
Post #509423 Sun Nov 06 2016 11:54am
Tvrprowler
Please keep us posted
Post #511723 Wed Dec 07 2016 12:44pm
Disco_Mikey
Pipes have been dropped off as a template. Won't be this side of Xmas, as they are flat out
Going to tack together a set, I'll pick them up and check fitment before committing to any number of them
Post #511732 Wed Dec 07 2016 1:48pm
Socast
I would be interested in a set for the 4.2SC, they can't be that different to the 3.6tdv8 (can they?). Bow down
Post #519160 Mon Feb 27 2017 3:41pm
Disco_Mikey
Completely different
Post #519201 Mon Feb 27 2017 8:22pm
Disco_Mikey
Picked these up this morning Cool
Made of 314 Stainless Steel, TIG welded, straight through with cat shell welded in place. Slightly larger bore than standard, but correct size outlet on the slip joint.
Still to test fit, and see if any adjustments are needed, but they fit the jigs made up exactly the same as the standard pipes
Expected cost is £375 + VAT, or £450 inclusive
Post #528794 Thu Jun 22 2017 10:10pm
d-9
They look good. Interested to know if they make much difference to performance and sound.
Post #528805 Fri Jun 23 2017 8:57am
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
Do we have any update? MOT , performance , smell , etc...I´m interested Wink TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #570436 Tue Dec 04 2018 6:49pm
alerton
Hi, i know this is an old post but i was wondering if anyone can tell me if these downpipes can be removed without too much difficulty? i'm looking for my first RRS and seen a tdv8 i like the look of but it has a blow on one of the downpipes which would need welding / repairing. i have no problem getting it welded IF i can get off off the car, the old guy who will be welding it is brilliant but refuses to weld anything that is still on a car, he is a pipe welder who like to be able to see / move / rotate his work piece which is hard when its on the car Smile . thanks everyone, i hope to be joining the RRS team soon.
Post #647783 Sun Apr 27 2025 10:52am
