![]() | Home > General > Fluid Puddles Under The Car |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
Fill in your car details in your profile.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
I have one! MY2007 HSE
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
It's an active anti roll bar (Dynamic Response). It's leaking but if it's just from the connection to the bar then it might be a cheapish fix. Worst case is a new anti roll bar which is £1000+ fitted. Get it looked at ASAP.
Maybe someone more knowledgeable can tell you.
Thanks guys, I'll top it up and get it looked at ASAP.
Its the rear ACE Bar - knackered |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2022 ![]() ![]() |
I'm sure I read you can try replacing some seals before shelling out on a new one.....? Worth a try.
