Home > General > Fluid Puddles Under The Car
Pufftmw
Noticed some drops under where the RRS normally parks, so had a look underneath and noticed a lot of oil(?) on the part of the car in the first pic (Can't get my mac to get it not upside down to upload? Sorry!.
Put it in raised and shuffled underneath and I can see that this cylinder with two banjos is absolutely covered - what is that?
Looking at the excretion dripping down, its clear but feels like oil or possibly hydraulic fluid.
What do you think is up with the car please?
Post #508434 Sun Oct 23 2016 7:49pm
Fill in your car details in your profile.
Check the fluid level in the container by the drivers headlight if you have one
Post #508436 Sun Oct 23 2016 7:53pm
Pufftmw
I have one! MY2007 HSE
AND
Its a bit below "Low"
What is it & what's likely wrong?
Post #508438 Sun Oct 23 2016 8:03pm
It's an active anti roll bar (Dynamic Response). It's leaking but if it's just from the connection to the bar then it might be a cheapish fix. Worst case is a new anti roll bar which is £1000+ fitted. Get it looked at ASAP.
The bit in the first picture is the rear diff mounting. It's below the rear anti roll bar.
Oh, and be careful getting under the vehicle just using off road height. The system is not unknown to drop without warning. A 2.5 tonne vehicle needs an axle stand under the chassis rail if you're lying under it. 2012 SDV6 - it's missing a couple of cylinders
Post #508440 Sun Oct 23 2016 8:08pm
Maybe someone more knowledgeable can tell you.
Could be the ARC anti-roll bar
Post #508441 Sun Oct 23 2016 8:08pm
Pufftmw
Thanks guys, I'll top it up and get it looked at ASAP.
Fortunately I'm a skinny fecker so don't need to raise the car but point taken.
Post #508447 Sun Oct 23 2016 8:56pm
Pufftmw
Its the rear ACE Bar - knackered Sad
Time for a new one...
Post #510260 Thu Nov 17 2016 5:53pm
DrRob
I'm sure I read you can try replacing some seals before shelling out on a new one.....? Worth a try.
Apologies if you've explored this option already Thumbs Up Visitor from fullfatrr.com
Post #510269 Thu Nov 17 2016 8:26pm
