| RRSPORT.CO.UK | ||
|  | Home > Technical > rubber bung on top of engine |
| Dave_telford Member Since: 15 Feb 2016 Location: Shropshire Posts: 22      |
 can any body tell me what the rubber bung does on top of a v8 engine
|  Wed Oct 19 2016 3:12pm |
|  Thu Oct 20 2016 5:18am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | A wider engine pic would be good.
|  Thu Oct 20 2016 6:31am |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | I'm pretty sure it's just a plug.
|  Thu Oct 20 2016 8:56am |
| Dave_telford Member Since: 15 Feb 2016 Location: Shropshire Posts: 22      | on start up the engine revs to 4000 rpm for a couple of seconds and then back down to appox 450 rpm  she is miss firing and I have lack of power ever since I change the supercharger (I had a knocking noise top end I  took the top off the charger and found  shinny metal on the veins suggesting the veins were hitting each other hence the knocking noise)
|  Thu Oct 20 2016 11:47am |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | The knocking could well have been the coupler. The tensioner spring goes weak in them, so when the engine is at idle you can get a knocking sound. This is due to there not being a constant load on the pulley.
|  Thu Oct 20 2016 1:30pm |
| Dave_telford Member Since: 15 Feb 2016 Location: Shropshire Posts: 22      | hi thanks for the reply I am in the process of putting it all back together now with the old supercharger I have got a brand new throttle body top the part with the electronics on it hopefully this is what you mean by the pedal rheostat. the car its self has done 125k I don't know the condition of the spark plugs as I can not move them (don't want them breaking off on me )have tried spraying wd40 down the reassesses plus normal oil to see if this frees them up (no joy)
|  Thu Oct 20 2016 1:49pm |
| Posting Rules
