![]() | Home > Technical > rubber bung on top of engine |
| Dave_telford Member Since: 15 Feb 2016 Location: Shropshire Posts: 22
can any body tell me what the rubber bung does on top of a v8 engine
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
A wider engine pic would be good.
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594
I'm pretty sure it's just a plug.
on start up the engine revs to 4000 rpm for a couple of seconds and then back down to appox 450 rpm she is miss firing and I have lack of power ever since I change the supercharger (I had a knocking noise top end I took the top off the charger and found shinny metal on the veins suggesting the veins were hitting each other hence the knocking noise)
The knocking could well have been the coupler. The tensioner spring goes weak in them, so when the engine is at idle you can get a knocking sound. This is due to there not being a constant load on the pulley.
hi thanks for the reply I am in the process of putting it all back together now with the old supercharger I have got a brand new throttle body top the part with the electronics on it hopefully this is what you mean by the pedal rheostat. the car its self has done 125k I don't know the condition of the spark plugs as I can not move them (don't want them breaking off on me )have tried spraying wd40 down the reassesses plus normal oil to see if this frees them up (no joy)
| All times are GMT |
