![]() | Home > General (L494) > Service needed already. |
I think also you will find that there is a disclaimer in the owner's manual to the effect that it also depends on use, not just elapsed time and miles. Do you use the car for a lot of city driving? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
| wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Double check your oil level is not rising, as this can be caused by failed DPF regens, and pollutes the sump with diesel fuel, with disastrous effects on the engine.
| GJW1 Member Since: 19 May 2015 Location: UK Posts: 447
I use it mainly mainly around town for 10 to 20 mile trips average.
Oil level is at half way and I've never topped it up.
The reason is the short drives in the city, the car may have plenty of oil but the quality may have reduced significantly with carbon in it - that is down to usage. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks Tim,
| IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 874
This is interesting I assume from this thread and subsequent posts that the RRS has oil quality sensors built in like modern day trucks. If this is the case would anyone know what the sensors check ? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
| HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254
I believe they monitor the oxidation of the oil. |
There are quite a few different methods, some as simple as monitoring how the vehicle is driven to more accurate and complex method such as oil analysis. I would really like to know if our cars have the cheap version or the technology version.
I'll have a fiver on the cheap one.............. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
If you have the service pack why are you worried that the service required icon is on? Problem is that if you don't service it within the 28 days or a small leeway after that then LR could hold it against you (as they have been known to) for not heeding the warnings to service it and then having a failure. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I wasn't worried Tim was just after a few opinions as the figures didn't add up to me.
Think this goes to how the oil quality is assessed. As per the link if it is usage based ten an early service may appear even though the oil is in good shape, no matter what you have to have it done for warranty purpose. I am interested to know if it is usage based because the oil could be well worn out and doing damage due to other factors and one will not know. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
28 days?
| All times are GMT |
