Home > Technical > Engine & Suspension mounts
erickwan
Malaysia
How often do these go on a RRS TDV6 MY2009. I have the tiniest of driveline vibration somewhere between 1600-1800 rpm on very gentle acceleration. Vibration is most pronounced accelerating gently up a slope, especially round an uphill bend.
Post #506568 Wed Sep 28 2016 5:02am
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Mm... this might be the early signs of the center bearing going on your rear propshaft. It eases as the speed increases, and is most obvious when accelerating up hill from a low speed.
It's not expensive or difficult to fix.
Post #506957 Mon Oct 03 2016 3:20pm
erickwan
Malaysia
Brand new propshaft already fitted. Vibrations greatly reduced, but not totally eliminated
Post #506964 Mon Oct 03 2016 5:23pm
CornishRob
I'm not sure if failing engine mounts would cause what you describe. More likely to cause a clunk, as you come on or off the power. (But I've not had problems with the ones on the RRS, so I can't be certain, but that's what they did in other cars.)
How many miles has it done, as the torque converter could be causing it. When I had a full gearbox flush, it cured a slight driveline vibration on mine a year or two back.
Post #507011 Tue Oct 04 2016 10:54am
