![]() | Home > Technical > Engine & Suspension mounts |
| CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174
Mm... this might be the early signs of the center bearing going on your rear propshaft. It eases as the speed increases, and is most obvious when accelerating up hill from a low speed.
| erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 153
Brand new propshaft already fitted. Vibrations greatly reduced, but not totally eliminated |
I'm not sure if failing engine mounts would cause what you describe. More likely to cause a clunk, as you come on or off the power. (But I've not had problems with the ones on the RRS, so I can't be certain, but that's what they did in other cars.)
| All times are GMT |
