Home > General > RRS battery drain solution found
Page 1 of 3 123>
B11rmo
HI,
I have been driving myself mad as to why my battery is draining.
I know the batter is ok as i have had it tested, but every morning when i try to start it, it struggles and sometimes if it doesn't start quickly then it fails then the jump leads come out (not what you want when you want to get to work)
Having search forums etc and tried knocking everything off electric, I found that the bottled release button (rubber cover) is the fault. When you peel the rubber off the switch you will see all the corrosion/acid fall from the switch, if this happens then i am 99% sure that his was your problem.
I am so happy that i have not even had time to replace the switch yet i have just left the cover off angiven the contacts a little clean.
Great news !!! Very Happy
Post #502664 Fri Aug 12 2016 12:33pm
TPS
bottled release button?? -----------------------------------------------
RRS SDV6 HSE MY2012 Orkney grey, Oxford leather Ivory seats Ebony carpet, Anigre wood trim, enhanced design pack.
Post #502690 Fri Aug 12 2016 9:43pm
Johnski
Think it's part of the not often heard of optional Bar fittings pack, bottle opener button? Whistle Very Happy John
Post #502692 Fri Aug 12 2016 9:54pm
TPS
Rolling with laughter Rolling with laughter -----------------------------------------------
Post #502698 Fri Aug 12 2016 11:54pm
SRE
Spain
Scouse spec Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #502702 Sat Aug 13 2016 7:58am
To the OP, well done - it's always nice to find an easy and cheap fix. You should have done some searching on here - the boot switch corrosion issue is fairly well known and documented. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #502724 Sat Aug 13 2016 1:27pm
B11rmo
sorry "boot lid release button"
Laughing
Post #502887 Mon Aug 15 2016 2:10pm
pollawyn
United Kingdom 2006 Range Rover Sport Supercharged Cairns Blue
battery drain
Surprised My battery drain problem turned out to be a faulty door lock. Not only was my RRS continually trying to activate the faulty lock but I had inadvertently been leaving the car unlocked.
On a similar tack I had been suffering lots of false fault messages, suspension, engine, hdc, seat belts. Battery in good nick and kept in a good state of charge. Found a slightly loose battery to chassis earth connection. tightened about half a turn and all problems gone. I just love my RRS despite the niggles. Rolling with laughter past personal chariots
TVR S1, TVR Chimaera, Mercedes 500SL, all sadly missed but age demanded easier access.
Post #503316 Sat Aug 20 2016 9:51pm
B11rmo
Ok it seems that my boot release button wasn't the only problem!
My battery is still draining any other ideas people?
Crying or Very sad
Post #503436 Mon Aug 22 2016 8:49pm
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Did you find a solution to your battery drain?
In the same issue now.
Battery new
Alternator fine
Just want to start going through the options. EXACTLY what I need on Monday morning!!! 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #506405 Mon Sep 26 2016 7:08am
darrenmcneill
Also,
Is it possible to doable the boot release so it doesn't drain, ie remove it until a replacement is sourced 2006 HSE for Sale - £7,499 (Manchester)
Post #506406 Mon Sep 26 2016 7:19am
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Heck doesn't anyone read what they've just typed Whistle
Post #506408 Mon Sep 26 2016 7:41am
darrenmcneill
No, not when they now have to drive the Mrs to work, get 2 kids ready for school, and work out how to do s school run plus 2 jobs with 1 car...
But actual advice would be appreciated rather than a spelling lesson. 2006 HSE for Sale - £7,499 (Manchester)
Post #506411 Mon Sep 26 2016 8:11am
CornishRob
Mmm... yes the rest of us aren't busy at all, so have plenty of time to try and decipher your message before we can actually help you. Rolling Eyes
Post #506413 Mon Sep 26 2016 8:35am
darrenmcneill
Not getting into a silly debate, but unless you can help could you keep the comments off the post?
Greatly appreciated 2006 HSE for Sale - £7,499 (Manchester)
Post #506418 Mon Sep 26 2016 8:59am
Page 1 of 3 123>
