![]() | Home > General > RRS battery drain solution found |
| darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442
Ive just checked and I have a 5.4amp drain.
| CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174
That's (obviously) way to much. It should be something like 1-200 mA (0.1 - 0.2A).
Ok, getting there.
Looking at other posts, FL18 powers lots of things that are worth checking, ie
Current issues on the car are:
Yep, disconnect it, and see what happens.
Pulled off the tailgate switch and a gallon of cottage cheese water poured out... WTF???
Ok....
Sounds like you are measuring the current with the ignition on or partly on, hence the CD is active. You need to test it when it is locked, as some of the ECU's (ie the body control module) will only shut down shortly after the car is locked. So open the bonnet, then hold put something on top of the bonnet switch, so the alarm module thinks that it is still closed, then lock the car with all doors shut, and monitor the current. After a minute or two, all the modules should have gone into sleep mode, and you can measure the current drain with all the normal functioning modules switched off.
Cheers, was just thinking exactly the same thing about the alarm etc! Knew something wasn't quite right. 2006 HSE for Sale - £7,499 (Manchester)
[quote="CornishRob"]Sounds like you are measuring the current with the ignition on or partly on, hence the CD is active. You need to test it when it is locked, as some of the ECU's (ie the body control module) will only shut down shortly after the car is locked. So open the bonnet, then hold put something on top of the bonnet switch, so the alarm module thinks that it is still closed, then lock the car with all doors shut, and monitor the current. After a minute or two, all the modules should have gone into sleep mode, and you can measure the current drain with all the normal functioning modules switched off.
| Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054
Under the left (looking at the front) bonnet catch. You can probably use a screwdriver to push down on the switch
OK....
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Robbie over on Disco 4 posted this 'professional guide' to tracing battery drain:
| All times are GMT |
