![]() | Home > General (L494) > Never a Good Sign.... |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
I didn't think that diesels had "throttle butterflies"? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
DrFox1969 Member Since: 02 Feb 2016 Location: Adelaide Posts: 190 ![]() ![]() |
Thanks for all the comments on this.
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
You need to run this like a fox, good open road run to dust the cobwebs out required I think. Perhaps some low grade diesel, don't usually get this sort of build up on a new vehicle? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Hi IRbails,
Thinking about this the only way is via the intake plumbing, so possibly some bypass oil from a new engine bedding in , slight turbo seal leak perhaps ? Worth keeping an eye on I'd recommend pulling the intake off every now and then and checking the build up , mind you I was good at working on my V10 in this area not sure how easy it is for the RRS. If you can check it fairly easy it may alert you to a future issue if one does exist. It would concern me because there must be a cause and I would want to know if it just a running in issue , PVC valve or whatever , but for the low k's you have up so far this should not occur IMO. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
I agree with your sentiments.
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
Just had a look at the throttle body diagram and EGR connections are after the flap (air flow direction) but still quite close to the flap so soot could have been introduced from the recirculated gases.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 417 ![]() ![]() ![]() |
The EGR inlets into the inlet ducting are just downstream (about 100mm) of the throttle valve butterfly shaft and pointing against the direction of flow at about an angle of 30 deg. from the axis of flow (i.e pointing directly at the throttle valve butterfly). So if the vehicle spent a lot of time at idle or low load it may be possible to build up carbon deposits around the throttle valve butterfly.
Love to know if blocking off the EGR gives rise to a fault code.Looks like a blanking plate would not be to hard to make, fitting it might be an issue though. I tried blocking the EGR on my R50, produced a fault, earlier versions of the V10 could be blocked without a fault. Seems EGR causes lots of issues, notice they regularly get blocked off by Land-cruiser owners. Does the SVD8 have a water cooled EGR ? These caused a lot of issues in the VW world from leaks. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
I believe all modern turbo diesels have a water cooler in the EGR system to cool exhaust gas prior to entrance into the inlet system. An air cooler would not be practical for the duty.
Let's hope these don't leak, I am not a fan of sticking exhaust gases into the intake. Understand the logic, but seems there are a lot of dissenters to the practice. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
With the recent VW debacle it is interesting to see a large % of diesel vehicle owners who are prepared to disable the EGR system of their diesel vehicle so that the soot buildup issue goes away, similarly DPF removal is now becoming common place because DPF's cannot operate effectively in low speed low travel distance duties. And now we are starting to see problems with Urea injection systems. So how come VW is so guilty and yet individual owners can do similarly evil acts of disabling emission control systems and yet their is little comment in forums on their act.
I think this is a good explanation of what the EGR does
AJ1 Member Since: 06 Apr 2016 Location: Sunshine Coast Posts: 64 ![]() ![]() |
This is all assuming the the lovely dealer is telling the truth of course. Cmon guys. MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's. |
