Home > Faults & Fixes > Poor acceleration and black smoke - fixes not worked
Greywolf
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
I have used the forum extensively for advice since purchasing my 07 2.7 TDV6 last November but have a current issue which remains unresolved. I have a loss of acceleration from stationery (0 to 2000rpm and then the turbo kicks in) and black smoke appearing when accelerating hard. Once it is going it runs fine just slow to accelerate from start.
Following advice from the posts I purchased and replaced all 3 intercooler hoses with silicone ones although whilst the small one didn't seem to be on too tight none were split. I also removed, cleaned and checked the intercooler radiator - again no holes or splits. It hasn't made any difference.
Since then I have fitted a new MAF sensor and cleaned the MAP sensor. No better.
I also fitted new EGR valves a couple of months ago.
I have now taken it into a garage for a full diagnostic and they can't find any issues and all operating as it should be (fuel pressure, all electrical sensors, etc). My last hope today was that the accelerator sensor might be faulty which they checked as well. No such luck. All working fine.
Please help. Don't know what to try next. Overall the engine runs fine. No misfires or erratic in any way.
Also hasn't been modified or remapped.
Post #503508 Tue Aug 23 2016 7:17pm
deano_123
Have you checked the turbo?
Post #503537 Tue Aug 23 2016 9:08pm
Greywolf
Hi. Only in the sense that the garage has said it seems fine on the basis it kicks in at 2000rpm and there are no diagnostic codes registering om the car. Once the car is moving and has picked up speed it drives pretty much normal. Do you know of any other checks I can perform to tell if it is the turbo as obviously removing or replacing this is going to be expensive?
Post #503553 Tue Aug 23 2016 9:48pm
deano_123
Just saw its black smoke so doesnt sound like turbo seals and is an air/ fuel issue. I'd check the EGR isnt clogged then go from there checking the fuel side of things.
Post #503558 Tue Aug 23 2016 10:02pm
Greywolf
Hi. Update on my problem.
Having reached the conclusion it must be the turbo, I booked the car in with BEST TURBO's in Birmingham (Unit 8, 56 Dudley Road East Oldbury). You can easily find their web site on the internet.
These guys were superb. Dropped the car off last Saturday. Just picked up today. Total cost for fitting a replacement turbo including a full service only £1,560 quid!!!!!! I am amazed at the price as as most of you will be aware getting to and replacing the turbo involves removing the whole body off the car. They have done a top job. The car drives like new and no black smoke. It turned out the actuator fins or veins were all coked up and apparently is a common problem on higher mileage RR's. The best bit though is that since buying the car last November the max MPG it ever recorded was 26mpg. On the drive home from Birmingham it increased to 31.3MPG and is still climbing.
I would recommend this company to anyone who has similar turbo problems.
Post #504462 Sat Sep 03 2016 5:08pm
Bodsy
Site Sponsor
That's a result in the end. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #504521 Mon Sep 05 2016 1:48am
SRE
Spain
So now, will you be adding 2T to your fuel Question In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #504526 Mon Sep 05 2016 9:06am
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi SRE, which 2T oil is the best as i have read various stories.. Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #504588 Mon Sep 05 2016 6:18pm
SRE
Spain
If you 5 mins to spare Whistle
http://www.freel2.com/forum/topic878.html?highlight=2t In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #504737 Wed Sep 07 2016 10:32am
