![]() | Home > Faults & Fixes > Poor acceleration and black smoke - fixes not worked |
| Greywolf Member Since: 23 Aug 2016 Location: West Yorkshire Posts: 3
I have used the forum extensively for advice since purchasing my 07 2.7 TDV6 last November but have a current issue which remains unresolved. I have a loss of acceleration from stationery (0 to 2000rpm and then the turbo kicks in) and black smoke appearing when accelerating hard. Once it is going it runs fine just slow to accelerate from start.
| deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108
Have you checked the turbo? |
Hi. Only in the sense that the garage has said it seems fine on the basis it kicks in at 2000rpm and there are no diagnostic codes registering om the car. Once the car is moving and has picked up speed it drives pretty much normal. Do you know of any other checks I can perform to tell if it is the turbo as obviously removing or replacing this is going to be expensive? |
Hi. Update on my problem.
That's a result in the end. |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
So now, will you be adding 2T to your fuel |
| Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380
Hi SRE, which 2T oil is the best as i have read various stories.. |
If you 5 mins to spare |
