![]() | Home > General > Knocking noise from steering |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
Oh lorks this is one of the commonest subjects on the forum! Search anti roll bar bushes and drop arms ...theres plenty to read 😊 |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
Could be an inner / outer steering ball joint / lower wishbone ball joint or steering shaft u/j |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9131 ![]() ![]() ![]() |
A notchy steering action is likely to be the steering shaft UJ. Not unusual and reasonably straight forward / cheap to sort.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2020 ![]() ![]() |
You live in West Lothian so the obvious answer is..........take it to Disco Mikey in Dundee |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Nice one.. thanks for the varied replies, all very helpful indeed. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
You can't buy the UJ, only a complete shaft |
Thanks DM. Any chance of a link to a detailed guide on how to replace this? |
More awkward on the RRS with ARC, and a complete |
Thanks Disco_Mikey |
...in addition to recent answer from yourself RRSTDV8 regarding the 'moving the steering quickly side to side sounds like the dynamic ARB "characteristic" yes mines does have this and as a test I have temporarily taken fuse 9 out and the knocking noise has gone when I move steering wheel quickly left to right!!! on this note is this a viable fix and do you know what would require to be fixed to stop this knocking noise, is it a full new ARB system or any chance the noisy one can be fixed? |
There isn't a fix.LR say the noise is a "characteristic of the system" i.e. they all do that. |
I know the hours still have to be put in to fix all this broken stuff, but with the help of the guys on this forum including detailed guides on how to fix things I would probably not have given any of this stuff a go... but there you go, another one fixed with help from this forum... lower steering all nice and light and driving as it should. And onto the next issue... |
