Home > General > Knocking noise from steering
DerrekL
When I move steering wheel left to right, right to left or move steering wheel one way then the other quickly back and forth I get a knock that sounds like its coming from front of car.
When doing this motion I also get a flat spot in the steering as if the steering almost gets stuck when going round a round about or turning sharply.
Any thoughts or ideas what I need to look at or get changed? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #503104 Wed Aug 17 2016 11:26pm
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Oh lorks this is one of the commonest subjects on the forum! Search anti roll bar bushes and drop arms ...theres plenty to read 😊
Post #503166 Thu Aug 18 2016 7:35pm
aljo
Could be an inner / outer steering ball joint / lower wishbone ball joint or steering shaft u/j Thumbs Up
the list is endless Big Cry Big Cry
cant see a worn anti roll bar bush cause the flat spot
Post #503168 Thu Aug 18 2016 8:04pm
A notchy steering action is likely to be the steering shaft UJ. Not unusual and reasonably straight forward / cheap to sort.
The knocking when moving the steering quickly side to side sounds like the dynamic ARB "characteristic". Does your RRS have the active anti-roll bar? Easy way to check is look under the cill below the driver's door. If there is a block with several pipes leading fore and aft then it's got the active ARB system.
The noise is one of those "they all do that sir" things that Land Rover sort of expect us to live with. 2012 SDV6 - it's missing a couple of cylinders
Post #503186 Fri Aug 19 2016 12:01am
DrRob
You live in West Lothian so the obvious answer is..........take it to Disco Mikey in Dundee Thumbs Up Thumbs Up Visitor from fullfatrr.com
Post #503198 Fri Aug 19 2016 7:10am
DerrekL
Nice one.. thanks for the varied replies, all very helpful indeed. Thumbs Up
RRSTDV8 - when you say 'A notchy steering action is likely to be the steering shaft UJ' would you advise best to swap out the actual UJ itself or to go for a full steering shaft replacement. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #503408 Mon Aug 22 2016 10:36am
Disco_Mikey
You can't buy the UJ, only a complete shaft Thumbs Up
Post #503416 Mon Aug 22 2016 1:19pm
DerrekL
Thanks DM. Any chance of a link to a detailed guide on how to replace this? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #503421 Mon Aug 22 2016 3:37pm
Disco_Mikey
More awkward on the RRS with ARC, and a complete Censored on a TDV8
http://disco3.co.uk/forum/topic56798.html
Post #503430 Mon Aug 22 2016 7:42pm
DerrekL
Thanks Disco_Mikey Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #503442 Tue Aug 23 2016 7:53am
DerrekL
...in addition to recent answer from yourself RRSTDV8 regarding the 'moving the steering quickly side to side sounds like the dynamic ARB "characteristic" yes mines does have this and as a test I have temporarily taken fuse 9 out and the knocking noise has gone when I move steering wheel quickly left to right!!! on this note is this a viable fix and do you know what would require to be fixed to stop this knocking noise, is it a full new ARB system or any chance the noisy one can be fixed? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #503593 Wed Aug 24 2016 12:09pm
There isn't a fix.LR say the noise is a "characteristic of the system" i.e. they all do that. Confused 2012 SDV6 - it's missing a couple of cylinders
Post #503603 Wed Aug 24 2016 3:15pm
DerrekL
I know the hours still have to be put in to fix all this broken stuff, but with the help of the guys on this forum including detailed guides on how to fix things I would probably not have given any of this stuff a go... but there you go, another one fixed with help from this forum... lower steering all nice and light and driving as it should. And onto the next issue... Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #503938 Mon Aug 29 2016 8:31am
