![]() | Home > Wheels & Tyres > Changing wheels? Will the car pick up the new TPMS sensors? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
I thought the system just recognised them without programing, fit wheel/ tyre wait and leave car stationary for at least 15 minutes then drive a for at least 5-10 minutes above 16mph and they should register.
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 ![]() ![]() ![]() |
Hi Michael,
Thanks Col
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
Michael,
The Government think a lot of things are of value, but usually ends up joe public paying |
If TPMS actually monitored the individual pressure in each wheel I'd see the value there.
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 ![]() ![]() ![]() |
TPMS is a by-product, if you like, of ABS and stability control.
I sure the latest system does monitor the individual pressures in each tyre/wheel, the RRS 1 system just told you the pressure had dropped to around 25psi because out of curiosity I let a couple of tyres down to see at what point the light came on. as I said as a £400.00 option it was as much use as a chocolate teapot. Cheers Col |
Where can I get a chocolate teapot then? RRS (MY13) Santorini Black SDV6 HSE luxuary
Here you go.
hodjie Member Since: 13 Nov 2013 Location: United Kingdom Posts: 91 ![]() ![]() ![]() |
hahaha class |
