Home > Wheels & Tyres > Changing wheels? Will the car pick up the new TPMS sensors?
Cryptic23
Hi.
Just purchased some new 22 wheels and tyres (GENUINE 22" RANGE ROVER ALLOY WHEELS STYLE 17 BLACK)
I have been after them for some time and took the plunge.
Im slightly confused about the tyre pressure sensors though, Will the car pick the new ones up ok?
I have read some thoughts that you need to drive for 15 odd miles and then the car will register the new ones and all will be ok with no faults coming up.
i have also read though, that they will need to be programmed to the car other wise it will throw up a fault as since 2013 plates onwards (mines a 2016) the sensors are registered to the car.. If this is the case then either land rover can programme the new ones (god knows how much they will charge for that) Or i can have the original sensors put into the new wheels and therefore the car wont know the difference..
Anybody that can clarify the situation would be my hero!
Thanks
Post #503007 Tue Aug 16 2016 11:09pm
I thought the system just recognised them without programing, fit wheel/ tyre wait and leave car stationary for at least 15 minutes then drive a for at least 5-10 minutes above 16mph and they should register.
I fitted RRS 2 wheels on a RRS 1 on a couple of occasions and that recognised them o.k. wouldn't have thought L/R have gone backwards but I guess you never know, why not fit wheels and see what happens, won't do any harm and no worse off.
Post #503018 Wed Aug 17 2016 3:56am
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
How do I determine if my RRS my12 has TPMS or not?
Michael RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #503035 Wed Aug 17 2016 10:47am
Hi Michael,
It should come up on the dash display when you switch the ignition on and say something like tyre pressures set to light/heavy load. Have a look at your wheels TPMS valves are metal, standard one's rubber.
To be honest on the RRS 1 it is a £400.00 waste of time option as doesn't give pressure readout just puts light on if pressure drops to around 25psi.
Post #503036 Wed Aug 17 2016 11:06am
LG8340
Thanks Col
That suggests I don't have TPMS.
Is there any benefit in fitting after market units?
Post #503038 Wed Aug 17 2016 11:23am
JOCK55
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
Michael,
The Government must think they are of value as they are a legal requirement on vehicles built from 2014 onwards!
Old Jock 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles.
2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten.
Post #503067 Wed Aug 17 2016 3:22pm
The Government think a lot of things are of value, but usually ends up joe public paying Rolling with laughter, not saying it's a bad thing but is that not something else Europe forced on manufactures ?.
Post #503070 Wed Aug 17 2016 4:00pm
LG8340
If TPMS actually monitored the individual pressure in each wheel I'd see the value there.
But a general alert has limited appeal.
Please tell me I'm wrong if I am! RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #503071 Wed Aug 17 2016 4:07pm
Slim444
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
TPMS is a by-product, if you like, of ABS and stability control.
It 'simply' measures any rotational speed difference of the wheels, if a particular wheel is going faster than the others (in a straight line) then it flags it as a low pressure. The steering wheel position sensor is used too, as when cornering, the wheels will travel at different speeds anyway. A flat tyre will effectively give the whole wheel a smaller radius / rolling circumference, so it will have to travel faster (more rpm) to cover a set distance compared to properly inflated tyre. Hope this makes some sort of sense?
Anyway, to answer you initial question, TPMS shouldn't have any issues calibrating to a change in wheel / tyre size...
It's Voodoo, Jim, but not as we know it Wink
Post #503072 Wed Aug 17 2016 4:28pm
I sure the latest system does monitor the individual pressures in each tyre/wheel, the RRS 1 system just told you the pressure had dropped to around 25psi because out of curiosity I let a couple of tyres down to see at what point the light came on. as I said as a £400.00 option it was as much use as a chocolate teapot.
Post #503074 Wed Aug 17 2016 4:51pm
LG8340
Where can I get a chocolate teapot then? RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #503075 Wed Aug 17 2016 4:57pm
Here you go.
https://www.firebox.com/Chocolate-Teapot/p7499
Post #503077 Wed Aug 17 2016 5:09pm
hodjie
United Kingdom 2011 Range Rover Sport Supercharged Autobiography Fuji White
hahaha class Rolling with laughter
Post #503539 Tue Aug 23 2016 9:13pm
