![]() | Home > General > Jack and Adaptor |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
Looking for a Jack to change wheels and clean up my calipers on my 2011 plate RRS,
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2021 ![]() ![]() |
Very timely.
Good spot! I hadn't noticed that!
You could try contacting the OP of this thread http://www.rrsport.co.uk/forum/topic30969.html
I have purchased the SGS 3 Ton Workshop Jack, and it is very well built, "but" is very heavy and not easily manageable. As said the rubber cover and the lifting top are no use as supplied to lift the cars at jacking points. There was a member on here before who had the adaptors made, whether they are still available I don't know. I purchased from a member on here earlier in year, so was lucky. This one on EBay may help, it has the a lug top and bottom. http://www.ebay.co.uk/itm/LAND-ROVER-RANGE...2198909956 John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Perfect! That is by the same seller. |
A "heavy" jack is a stable jack |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9132 ![]() ![]() ![]() |
A 3 tonne jack is always going to be heavy. I have the Halfords version of the SGS one ( they look identical in every respect other than stickers) and it is heavy etc but it lifts the RRS nicely. 2012 SDV6 - it's missing a couple of cylinders
Going to order this Jack, but want some axle stands too, obviously they need to be 3 tonne of above, but do they need to be a certain height? |
