Home > General > Jack and Adaptor
J2D
Jack and Adaptor
Looking for a Jack to change wheels and clean up my calipers on my 2011 plate RRS,
After doing some research on here I think I have found what I'm looking for (links below).
Can someone confirm I'm on the right track before I order, or if anyone has any better recommendations?
http://www.sgs-engineering.com/garage-equi...olley-jack
http://www.ebay.co.uk/itm/LANDROVER-RANGE-...SwUuFWyNQJ
Thanks in advance
John
Post #502495 Wed Aug 10 2016 9:48am
DrRob
Very timely.
I did the same research and have just ordered the SGS jack you linked to.
I can't comment on the adaptor as I wanted to wait to measure the pad hole on the SGS before I purchased one (That supplier does a 60mm and a 74mm). Will do that at weekend.
You can also just use jack on the control arms and not via chassis which means you don't have to jack the car up as high = safer Thumbs Up * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #502503 Wed Aug 10 2016 11:03am
Paddi
The SGS jack looks the same as one I bought from there 3 years ago and it has been fine.
Not so keen on the jack adaptor you linked to. The adaptor which you'll find mentioned on the forum (with a drawing) has a lug top and bottom so fits in the jack with the 'cup' removed and also locates in the chassis. Helps to stop the jack slipping off.
The eBay version looks to only have the top lug and is recommended to be used with the jack cup in place; that doesn't sound as secure. 2008 MY Java Black TDV8 HSE
Post #502505 Wed Aug 10 2016 11:43am
J2D
Good spot! I hadn't noticed that!
Any idea where I can get an adaptor that has a lug at the top and bottom?
John
Post #502527 Wed Aug 10 2016 4:17pm
Paddi
You could try contacting the OP of this thread http://www.rrsport.co.uk/forum/topic30969.html
via PM here and on the Disco 3 site or just making a general appeal via another post on both sites. The product is a work of art in beautiful stainless steel but not sure if he'll be making any more or sells them elsewhere.
Sorry - not all that helpful I know
EDIT: just noticed comments above and it seems the eBay seller does make a suitable one: http://www.ebay.co.uk/itm/LAND-ROVER-RANGE...Sws4JW7BLS 2008 MY Java Black TDV8 HSE
Post #502529 Wed Aug 10 2016 4:32pm
Johnski
I have purchased the SGS 3 Ton Workshop Jack, and it is very well built, "but" is very heavy and not easily manageable. As said the rubber cover and the lifting top are no use as supplied to lift the cars at jacking points. There was a member on here before who had the adaptors made, whether they are still available I don't know. I purchased from a member on here earlier in year, so was lucky.
This one on EBay may help, it has the a lug top and bottom.
http://www.ebay.co.uk/itm/LAND-ROVER-RANGE...2198909956 John
Post #502530 Wed Aug 10 2016 4:33pm
J2D
Perfect! That is by the same seller.
Post #502537 Wed Aug 10 2016 5:11pm
DrRob
A "heavy" jack is a stable jack Thumbs Up * Current: 2024 D350 Defender 90 on coils!
Post #502549 Wed Aug 10 2016 8:27pm
A 3 tonne jack is always going to be heavy. I have the Halfords version of the SGS one ( they look identical in every respect other than stickers) and it is heavy etc but it lifts the RRS nicely. 2012 SDV6 - it's missing a couple of cylinders
Post #502550 Wed Aug 10 2016 8:38pm
J2D
Going to order this Jack, but want some axle stands too, obviously they need to be 3 tonne of above, but do they need to be a certain height?
Post #504145 Tue Aug 30 2016 9:51pm
