![]() | Home > Faults & Fixes > Tdv8 2009 rrs turbo issues |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 ![]() ![]() ![]() |
Thanks Paddi once again,
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9119 ![]() ![]() ![]() |
The squeaking after shut down is the EGRs cycling to ensure they don't jam up. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
The turbos also cycle on start up and shut down |
ragpicker Member Since: 21 Mar 2016 Location: Teesside Posts: 47 ![]() ![]() ![]() |
Turbo's or EGR's, should they squeak? If its a sign of something, what can I do about it?
At least if the turbo actuator rods are squeaking you know something is moving! The rods can be lubricated from below if you remove the plastic shielding but its a long reach up to them. Search the forum and you'll find various ingenious methods including straightened out coathanger with tubing zip tied it used as a means of extending the reach of teflon spray.
Had my suspension re-callibrated today by a local indy (Oakfields - stockton). Whilst in there I mentioned it to the chap and he said that there are several things which cycle when the ignition is switched off - the egr's, the turbo actuators, the throttle bodies, the air flaps and something else apparently??
