![]() | Home > Australia & New Zealand > TOWING ISSUES |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
Just a quick bit of information.
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
Interesting, as i have towed a 950 KG off road Camper and a 1.2K KG Camper trailer both on
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
A note on the e-bay hitch. It works, but is a little sloppy in the fit . OK for taking the rubbish to the tip but would most likely go for a better solution if I was towing a van. Hope this helps. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Yes but most modern hitches have a bolt that you tighten to stop any of this slack - I guess the LR hitch does not have this.
Surprisingly quite in the tow , Ball height was a little low but did the job . For $45 vs $280 it was value for what I wanted. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
I think I know what the problem with the movement may be, as when I checked mine it was a little loose in the fitting into the receiver.
They are all a little loose and rattle - nothing new there, that is why some receivers have a bolt you tighten to take the little bit of slack up.
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 154 ![]() ![]() |
I towed my 2 ton twin axle caravan with I Mitsubishi Pajero for 6 months and towed great. When I bought my 2009 Range Rover sport and towed it with that it was a litlle scary at first as had a little sway and was a little more bumpy I think because of the air suspension. Now I get none of that after 12 months of towing it's as if the car has learnt and adjusted it's self . Sometimes it feels like the caravan is not on the back. My tow ball weight is 170kg and I dont use the swan neck tow hitch. I use the genuine square one which sits a little higher then the swan neck. And I tow around the south island of new zealand which can be a little bumpy. |
