![]() | Home > Technical > Fault code, identify repair |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2026
Take it to Steve Norman..... * Current: 2024 D350 Defender 90 on coils!
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
Are you getting symptoms with those codes? If not, just ignore them. |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Are you having any problems with the vehicle?
| Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203
Thanks for replys, no doesn't seem to be affecting anything, I've disconnected the drl wiring harness and cleared faults (took for small drive) and codes not bk as yet so think it's that, can I get resisters to put on drl wiring harness to stop any codes, prob will be fine but I'm a bit ocd, |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
When I reprogram or activate anything using my IID BT unit, I always end up with a long list of faults, brake assist, Traction control, etc all stated as missing or non operative, giving warnings to drive carefully to a workshop for assistance, the Windows will no longer operate as one touch. The clock and the radio generally have lost their memory, as have all the Sat Nav favourites.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
Just ignore the lost comms unless something not working |
Mmmmm ok maybe not DRLS causing faults as they have returned so just going to ignore unless cause any issues, |
http://www.tandsnorman.com
Thanks DrRob, will def use them as not too far from me. Thanks a lot. 👍 |
| All times are GMT |
