Home > Technical > Fault code, identify repair
Gilly1
hi all, I have TRIED (I say tried because I don't no if I've done correct or not) re calibrate suspension. So confused & didn't take note or save original settings before I messed about. I've also fitted LED DRL,S.
Ride height is pretty level/similar on all corners & all settings seem to all work ok.
CODES IN INSTRUMENT PACK
U0132 Lost communication with ride level control module
U0182 Lost communication with front lighting control module
U0159 lost communication with park distance control module.
Cleared faults with IID but come back soon after.
Post #501103 Mon Jul 18 2016 10:32am
DrRob
Take it to Steve Norman..... * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #501122 Mon Jul 18 2016 3:50pm
Lost for Words
Are you getting symptoms with those codes? If not, just ignore them. Thumbs Up
The good news is that the IID has already saved your original settings for you, so you can revert if necessary. Smile Visiting from DISCO3.CO.UK
Post #501123 Mon Jul 18 2016 3:57pm
Paddi
Are you having any problems with the vehicle?
Whenever I scan my vehicle with the IID Tool I almost always find:
and
and some other to do with the HVAC unit (which I am told are always seen).
Talk to any diagnostics technician and they will tell you that 'lost communication codes can usually be ignored'
Assuming your front lights are all functioning normally - there is probably nothing to worry about.
must type faster Laughing 2008 MY Java Black TDV8 HSE
Post #501125 Mon Jul 18 2016 4:03pm
Gilly1
Thanks for replys, no doesn't seem to be affecting anything, I've disconnected the drl wiring harness and cleared faults (took for small drive) and codes not bk as yet so think it's that, can I get resisters to put on drl wiring harness to stop any codes, prob will be fine but I'm a bit ocd, Embarassed
DrRob who/we're is Steve Norman. Very Happy
Post #501126 Mon Jul 18 2016 4:11pm
Johnski
When I reprogram or activate anything using my IID BT unit, I always end up with a long list of faults, brake assist, Traction control, etc all stated as missing or non operative, giving warnings to drive carefully to a workshop for assistance, the Windows will no longer operate as one touch. The clock and the radio generally have lost their memory, as have all the Sat Nav favourites.
Next morning everything that had disappeared as not working,(it generally takes three hours to all clear) now shows no faults and none shown on tester. Have to reprogram clock, Sat Nav favourites, and reset windows to operate under one touch, everything works ok, I have contacted makers, and they say it shouldn't be behaving like that, but currently cannot offer a solution, and I will be returning for correction or refund.
For info the unit is official stock, been updated to latest version, and registered, so must be a fault unless anyone knows otherwise? John
Post #501138 Mon Jul 18 2016 6:52pm
Just ignore the lost comms unless something not working
Post #501144 Mon Jul 18 2016 7:30pm
Gilly1
Mmmmm ok maybe not DRLS causing faults as they have returned so just going to ignore unless cause any issues, Mr. Green
Post #501255 Wed Jul 20 2016 6:48am
DrRob
http://www.tandsnorman.com
Very well respected on here and Disco3 Thumbs Up * Current: 2024 D350 Defender 90 on coils!
Post #501342 Thu Jul 21 2016 7:54am
Gilly1
Thanks DrRob, will def use them as not too far from me. Thanks a lot. 👍
Post #501363 Thu Jul 21 2016 11:38am
